Okay this post may be sorta long so bear with me. I recently purchased a used 97 Subie Legacy Outback from a mechanic. As it was owned and maintained by this mechanic since he bought it new, I figured everything would be in good operating condition...and for the most part it was. I drove this car for 3 months no issues then a few weeks ago I started noticing an overheating problem. The gauge would go from the normal reading to all the way past the H mark. The car showed no signs of overheating, no steam, odd engine noises,etc. The coolant was low so I filled it up and would truck right along for another 2 weeks until the problem presented itself again.
Last week it got to the point the car shut itself off (is this some sort of safety feature??). I let the car sit for about 45minutes and the temp went back down and the car started right up and I made my way home.
I first thought it was a pinhole leak in the radiator but after extensive inspection while the car was running hot I saw no leaks anywhere. I looked on the forums here and many suggested it may be the radiator cap. I replaced that yesterday, topped off the system and thought the problem to be solved. Since then an even odder problem has started. The car still overheats but now the heater just blows out cold air. No really, the heat will work great until it begins to overheat then the vents only blow out cold air. Just this morning I was able to make it from my house into town (appx. 17 miles) before the issue reared its ugly head. Still, aside from the gauge showing extremely hot, there are no signs of overheating. No steam or smoke from engine, car still runs very smooth, and it doesnt have any of the odd noises associated with an overheated car.
At this point I'm quite baffled. I've checked everything. I know for a fact from the burping process that coolant is definitely cycling through the system. I also know that this could be signs of a blown HG but there are also no signs of that either. No oil in coolant, no thick white smoke coming from exhaust...nada....and again the car runs smoothly when driving and fine when idling.
I'd greatly appreciate any input on this as I won't have the means to take it to a mechanic until Janurary and this vehicle needs to get me back and forth to school and work until then.
Thanks in advance.
