bluesteel1973
Everything posted by bluesteel1973
I've looked as best as I'm able, it has some forward back play and spins free, no signs of a pin. What bolts normally hold the shaft on the at end? If it didn't have something holding it there nobody would be able to remove the rear section of rear drive shaft without the front half from falling out, know what I mean? Thanks for the reply.
Good morning/afternoon respectively, I'm trying to put on a drive shaft on a car that I purchased that was missing rear drive shaft. It is an automatic, so the PO left the the first joint coming off the spline on the car so that ATF wouldn't spill out and could be driven FWD. Problem is, I can't figure out how to remove it despite having a 3000+ page manual lol. Secondly, is there any way to use a WRX driveshaft from a manual transmission on an AT? I realize I can use a companion flange on the diff side, but what about the transmission side? Thank you for reading and any suggestions or direction.
Thank you everybody for your help pointing me in the right direction. I had a few delays with the weather and holiday chores. The header has a badly pinched pipe on both side that has got to be killing my air flow tremendously. And since I recently found out that my impreza is also missing the rear drive shaft, might that play a role in it feeling very sluggish on acceleration? It is in F W D mode now. I got a manual rear drive shaft locally for a good deal, and supposedly you can adapt it to work on a AT if you swap the yoke section at the tranny end. I have no idea how the last section aka yoke, output shaft, propeller etc. If anyone has any suggestions, I'd be grateful to hear them. The AT shafts seem to be hard to find locally. If I could post pictures, I could more easily convey what I am dealing with.
Thank you, that's kind of what I figured as far as keeping old harness, though I was under the impression that the RS was a 2.0 motor. I am going to change all the plugs and use the ones suggested for boosted vehicles as I plan to throw on a small turbo and boost no more than 9 lbs, I was also given some 440cc 3920 injectors, and a new unisia Jecs fuel pump, so might as well throw them on too. It almost seems like the PO eliminated the harness and MAF... CODES: P0851 PARK/NEUTRAL SWITCH CIRCUIT LOW P1518 STARTER SWITCH CIRCUIT P0512 STARTER REQUEST CIRCUIT P0137 O2 CIRCUIT LOW VOLTAGE BANK 1 sensor 2 P0138 HIGH VOLTAGE P0502 VEHICLE SPEED SENSOR A- CIRCUIT LOW INPUT P0503 " " INTERMITTENT/ERRATIC/HIGH P0113 INTAKE AIR TEMPERATURE SENSOR 1CIRCUIT HIGH INPUT P0037 HO2S HEATER CONTROL CIRCUIT LOW BANK1 SENSOR 2 Yeah, just a few...
Hi, thanks for the reply. I have searched lots on the internet and have seen where it is, on various cars, though it does vary. Bear in mind I have a 2003 RS impreza, with a 2005 2.5 forester motor. I don't know whether the MAF harness would be the original impreza harness and exit location or wherever it routes on a forester. Either way, I can't seem to find a plug that large anywhere. The hood is a CF hood so no diagrams, not that it would matter due to the different model motor. Very frustrating... The car did not even have intake plumbing when I bought it. The car starts right up ever time and is strong, but there is much unplugged I suspect.
Thanks again for taking the time to read and post. Check engine light is on, I will pull codes again, I know there are a couple generic O2 sensor ones, maybe an IAT as well. I'll scan again though. Unfortunately, I have no history on the vehicle whatsoever. I know nothing about it. It looks like kind of a hack job although it seems that all the electrical accessories etc in the car seem to be working. I also discovered last night that the rear drive shaft is missing! Not sure why the PO would've removed it, because I wouldn't think an engine swap would necessitate changing or even removing.
Thank you very much for the reply. I'm not really familiar with a MAP vs MAF. What should I know or look for? Where should I begin as far as why it seems lack power or that fuel air mix is off, an ECU flash? The brakes do feel like they may just need a bleeding, but since the ABS light was on, I figured it could've been associated, while they may be unrelated.
Hey everybody newb and reaching out to community for any help or suggestions. I bought a 2003 Impreza with a 2.5 engine swap, with what I'm told looks like a fresh rebuild. From what I can tell, it is a 2005 Forester motor. I bought it as a project, and it was priced well. Ok, it runs, goes into gear (AT), and "drives", not well. I figured it might need an ECU flash with a different tune, but when I was throwing on the CAI piping, I saw that there was no MAF. I went ahead and purchased a new one, and I cannot find the MAF plug anywhere. Is this something that should be near where the stock one was or in a different spot because of the other motor? I can't find any plug that looks that size. Additionally ABS light is on, and brakes seem spongy. I appreciate any help or advice in advance. BTW, its NA now but I'm planning on adding the stock WRX turbo setup, which I have.
