cleveland2895
Posts posted by cleveland2895
Okay so thankfully I replaced that wire and that was all that was wrong with it! Thank you guys for all the help. Also I only had the headlight issue once so if it happens again I will look into that more. Merry Christmas to you all and thanks again!
Thanks for the help guys but I believe I found my problem. I tore it apart today and here the guy that had it before me when he put a turbo timer in it he spliced a wire for the ignition in about three different spots, and the metal to the crimps he used are loose and exposed. So I hope once i replace the wire here it will work. But thanks for your guys help.
So i have a 2002 Subaru WRX and just recently it began not starting it does not do it all the time but sometimes when i go to start it all the lights will come on and work, but when i press the clutch and turn the key to start it you can hear it just click one time and wont start. It doesn't crank or anything its just a simple click sound...
Another problem I have is that when i turn the head light switch to the off position the headlights will stay on.
Anyone have any idea what could be causing these problems or have a solution to them?
Fender Rolling please help
Posted
okay so my 2002 wrx needs the rear left fender rolled bad there is a little piece that sticks out and is rubbing on the tires bad as i take a left turn. But where it has rubbed it has caused it to rust in one little spot. Now can i still roll that or from it being a little rusted will it not roll right and crack my bad really bad. I'm so scared to have it done, i don't want it to rust all the way up the fender!
