Logan Robinett
Posts posted by Logan Robinett
Also what would my mpg be?
Hi all, I'm looking to swap a 2001 legacy ej22 engine into a volkswagon bus. I have someone to help me as I am not yet "mechanically inclined" I was just wondering what parts I would need and around how much the whole proceedure would run me. I appreciate the help!
Hi all, I noticed that my car was leaking coolant and after having it looked at I was told it was from the intake manifold..I do not know where the intake manifold is but I'm assuming Ill most likely be able to change that gasket if that's what's wrong..any suggestions as to what I should do or were the intake manifold is located? Thanks
- 1
I did:) now if only it would idle it hasn't since I got it. It drives fine but if I stop giving it gas it chokes and dies
Gosh guys im so dumb. I just assumed black was negative and red was positive and hooked up the battery that way. I couldn't find what was wrong so I just said screw it and flipped the battery around and the thing started right up thanks for the suggestions though I appreciate it:)
I tried that and everything read .1
I like pictures.
2" front lift done yesterday. it cost me only like $5 for the hardware
lights on the bumper to see the sides of the road better. and the mesh grill. OH and finally license plates on it so its legal, even though I'm ordering my personalized ham radio ones tomorrow hopefully.
switch panel for offroad lights, etc. more to be added later.
Where did you get that hardware for the lift
Ive looked at it more and it is only the far rear fusible link that blows. It has a big white wire coming out the bottom of the box where the fuse is. Any idea what that might be?
Any suggestions as to where the short might be?
Hi all! Im sort of new to this whole thing but here it goes, I have a 1987 subaru gl base with the stock EA82 engine in it. Im 16 and I certainly dont know all that much about cars so Im not sure what could be going on but ill try to explain, I had removed the battery and when I went to put it back in I placed the positive wire to the positive terminal and the black box thats mounted to the coolant tank popped and start to smoke. All three wires that were in it blew in half and now when I go to start it nothing happens. The battery was in correctly im not that naive but im not sure what I need to do. Any suggestions?
ej22 volkswagon bus swap
Posted
I've seen the youtube videos, there's this one channel called "busaru" I appreciate all the help, thank you!! I'll post pictures once I start getting everything together
