kbrumley27
  1. I am having a similar issue with my 2001 Subaru outback. I cant get it to start and had to get it towed home on Christmas. Turned the key on and can not hear the gas pump starting up. This car is new to me. It has 195000 mi on it. Right after I first got it the check engine light came on so I hooked it up to scan it and it said the o2 sensor. Well the previous owner removed the catalyst and the o2 sensor along with it. Any how the reason I stated that was because I was able to get a read off the ecm. So now I tried to hook it up and it wont read anything. Tried multiple times. Disconnected the battery hoping to reset the ecm. Still nothing. Ive also had troubles with fuses blowing. My question is this, Is there a way to test the ecm to see if it is working properly and also where is the fuse for the ecm? It is not under the dash where the others are for audio and lights etc. Thank you in advance for all your advice.
