Yes, the clutch pedal switch. That's what I was calling it (actually clutch safety switch, but some guy at an auto parts store said it was called the Neutral safety switch).
Anyway, yes it has cruise control. The lower switch on the pedal is for the cruise disable, if one steps on the clutch. The upper switch is used for the starting circuit. I jumped it with some 16G wire that I crimped on a male spade connector on each end, and plugged into the upper connector, once I unplugged it from the switch.
I do have a voltmeter and can try some measurements while it's failing. Where is the interlock relay located?
thanks for the ideas,
