Everything posted by timberwolfz71
2004 subaru wrx sti platinum silver mettalic
Hey this forums awesome relit my spark take care guys and gals !
I downloaded the service manual so ill follow that unless you got a masters tip or two ? Thank you fair tax 4 u
Sounds like a plan , do I have to put the engine at top dead center and pull the belt, lining up all the marks and or secure cam and valve pullys so they don't move
thanks 777 for getting me rolling on here this weekend it's all happening pump belt and repair I'll keep you posted , reguards NEWBIE!
thanks mike , I concur ,I'm an Alaskan but my subarus been all over down there eastern Washington and Idaho it's even traveled on the ocean on a crab boat , used to sit in it and crank my music !
thanks Montana , great information .between myself the cannery engineer and our city shop mechanic they're confident in the procedure , so curious on how much the folded over woodruff key worked the channel edges , we'll find out this weekend were going. to line up all the timing marks ,and I downloaded proper procedure on timing belt change , no welding just jb weld and 661locktite and 140 lbs on the nut , love all these subarus on here guys !!!!!
hello 777 here it is ,a shocker for sure ,ive heard jb weld to fill and repair .when I was fishing I let the local mechanic here replace my belt .after I notice harmonic wabble this is what I found ,in addition I put a breaker bar on it and it almost crushed my knuckles as it was already loose so I hand backed it off ! jeepers any suggestions would be great im very mechanically inclined but new horizons scare me ,I downloaded timing belt process and have good help as well but the ultimate solution is out there thank you
Here is the photo, attempting to share the media not sure if this will do it.
I haven't removed the timing belt yet as I've been online getting detailed information on how to properly do that , also I'm having trouble posting pictures , do I have to compress pictures ?or is it simple like facebook
Subaru WRX sti
- 2004 subaru wrx sti platinum silver mettalic
Absolutely I will , just joined the forum to research various situations like mine. Off work and will get on shortly once I figure out how to post pictures to you , thanks a bunch for correspondence- Subaru sti alaska
Wabbly harmonic balancer ! Keyway twisted freaking out bigtime , remove keyway and crank sprocket carefully or is there anything I should know first ! Other than I'm screwed- 2004 subaru wrx sti platinum silver mettalic
my harmonic balancer started wabbling madly ,so i removed it and to my great distress the keyway is a twisted mess ,and the crank sprocket is shifted with the tweaked keyway as well ,do i wiggle it out anyway i can ,please help im stressing hard on this one as i live on an island ralley paradise ,can i be sure the crankshaft end is compromised????? - 2004 subaru wrx sti platinum silver mettalic
