subaru forever
Everything posted by subaru forever
  1. 2001 forester.no white smoke.no coolet in oil.no bubbies.nothing under oil cap.no leaks that i see.any help.adding a small amount each week
  2. bought a 2001 forester.only has center headrest in back seat.were the other 2 option?
  3. Ok.not sure if filter has ever been changed.may just drain and fill drive drain fill.thanks
  4. What type of transmussion used in a 2001 a-t forester.going to do a drain and fill.should i use lucis stuff?
  5. Can a aftermarket oxygen sensor be used .? Or oem only? Is the oxygen from a 95 wagon the same for a 2001 forester?
  6. Thanks.got a 2001 forester.for 800 bucks.187,000 mi.needing 1 brake caliper.knock sensor.alittle rust.interior good.
  7. Found 2003 outback limited ed.280,000 mi.new heads alot of other work.body good.like 800 bucks.just thinking about the hi miles.etc..opinions
  8. Yes replaced hazard switch with working one.where is flasher relay located.?behind radio?
  9. Looks like advanced auto has it.and did some part look up
  10. Yes.but they could have been bad.no harm finding this out
  11. I have replaced the 3 relays above fuse box.where is it located
  12. Is there way to by pass the bad switch.in the steering colium.the blinkers or 4 ways do not work
  13. I have asked this before.checked everything.relays.4way thing in dash.all fuses.lights work.brake lits.tail lights.no dome lite or blinkers.where can i tap into to reg up the blinkers
