Everything posted by subaru forever
using coolet
2001 forester.no white smoke.no coolet in oil.no bubbies.nothing under oil cap.no leaks that i see.any help.adding a small amount each week
headrest 2001 forester
ok.so there should be a total of 3 .thanks
bought a 2001 forester.only has center headrest in back seat.were the other 2 option?
oxygen sensor 2001 forester question
No.just changing fluids
Ok.not sure if filter has ever been changed.may just drain and fill drive drain fill.thanks
What type of transmussion used in a 2001 a-t forester.going to do a drain and fill.should i use lucis stuff?
Thanks
Can a aftermarket oxygen sensor be used .? Or oem only? Is the oxygen from a 95 wagon the same for a 2001 forester?
- opinion
- opinion
- opinion
blinker 4 ways 97 sedan
Yes replaced hazard switch with working one.where is flasher relay located.?behind radio?
Looks like advanced auto has it.and did some part look up
Ok.thanks
Under the dash behind 4way switch?
Is it square with 3 prungs?
Thanks will check out tomorrow.this will help
Yes.but they could have been bad.no harm finding this out
I have replaced the 3 relays above fuse box.where is it located
Checked 4way has power but does not work
Yes
Yes and relays.lights tail lights good.brake lights
Is there way to by pass the bad switch.in the steering colium.the blinkers or 4 ways do not work
I have asked this before.checked everything.relays.4way thing in dash.all fuses.lights work.brake lits.tail lights.no dome lite or blinkers.where can i tap into to reg up the blinkers
- four ways blinkers
