**COLORADO - Bar-B-Q** (10/05/2003)
looks like like i'll be able to make it too. marco
spring rates?
hi bushbasher springrates on a 85 4x4 wagon were: front 23.5 N/mm back 31.4 N/mm like i said it's from a 85, but i don't think it has changed through the model years. marco
loyale rs springrate?
does anybody know which springs the loyale rs had in the front? was it the "regular" set or the stiffer ones like in the rx? marco
EA-82T timeing
the timing difference probably has to do with mpfi vs. spfi. marco
scary
i wasn't really worried about the stereo, but i just put a rebuilt engine , new hoses, new radiator,new this and that in the car , so if they had stolen it, i would be screwed with what an insurance company would give me for it. plus i love my wagon. marco
scary
last night, somebody tried to steal my car right in front of my house. something must have scared them off. the only damage is around the ignition. the plastic was broken off and it looks like they tried to brake the lock with a screwdriver. weirdest thing, my stereo was untouched. guess i was pretty lucky after all. marco
the rx tranny
diff lock uses an electric switch that activates solenoids, which use vacuum to engage or disengage diff lock. marco
EA-82T timeing
hi calebz the 86 manual specs 25 deg btdc for turbos. marco
pug wheels
thank you calebz. marco
EA-82T timeing
hi subi the marks on my turbo's flywheel don't go to 25 either. if you couldn't adjust the distributor any further without taking the bolts off, then it is probably a tooth off. marco
pug wheels
checked the "what do i ask " thread again, but doesn't answer my question. are there other model pugs with the same lugpattern as subes? or was the 505 line the only one ? thank's, marco
pug wheels
hi jay if this is a repeat question, i have never seen a "repeat answer" to it on the board. and no, the search engine doesn't answer my question either. marco
pug wheels
hi guys. which peugeots have the same boltpattern as our subes? i know one is the 505, are there others? thanks, marco
5280wagon
