jessica 123
  • Location
    phoenix
  • Referral
    search subaru
  • Biography
    please help my car wont start
  • Vehicles
    1994 subaru impreza
jessica 123's Achievements
Newbie
Newbie (1/11)
0
  1. thank you for al of your help. I figured out the problem, the ignition switch was bad and the fuel pump sending unit is fried. Do you know where I can find parts?
  2. oh and I am trying to replace the ignition relay but I cant seem to get the old one out, is it screwed in? of does it clip onto a bracket?
  3. ok so I tried to jump the starter while turning the key and the starter turns over but the the motor will not and I tried starting the car in neutral but nothing happened, I tried to locate the the two black plugs that you were referring to but im not sure where they would be.
  4. I apologize I worded that wrong. the starter and the motor crank but the car does not start. thank you all for your suggestions I will try your suggestions tonight when I get home. thank, you again
  5. ignition switch? where would I find that? Its automatic, and it does try to start but will not.
  6. it will not do anything. I turn the key and the lights turn on but thats it, the starter cranks if I jump it with a screwdriver.
  7. I have replaced, the starter, fuel pump and ignition lock cylinder and the car will not start. please help
