Everything posted by jessica 123
94 subaru impreza will not start please help
jessica 123 replied to jessica 123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok thank you all so much. have a nice day
jessica 123 replied to jessica 123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXthank you for al of your help. I figured out the problem, the ignition switch was bad and the fuel pump sending unit is fried. Do you know where I can find parts?
jessica 123 replied to jessica 123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXoh and I am trying to replace the ignition relay but I cant seem to get the old one out, is it screwed in? of does it clip onto a bracket?
jessica 123 replied to jessica 123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXok so I tried to jump the starter while turning the key and the starter turns over but the the motor will not and I tried starting the car in neutral but nothing happened, I tried to locate the the two black plugs that you were referring to but im not sure where they would be.
jessica 123 replied to jessica 123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI apologize I worded that wrong. the starter and the motor crank but the car does not start. thank you all for your suggestions I will try your suggestions tonight when I get home. thank, you again
jessica 123 replied to jessica 123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXignition switch? where would I find that? Its automatic, and it does try to start but will not.
jessica 123 replied to jessica 123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXyes everything electrical works, and the ground wire is connected.
jessica 123 replied to jessica 123's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXit will not do anything. I turn the key and the lights turn on but thats it, the starter cranks if I jump it with a screwdriver.
I have replaced, the starter, fuel pump and ignition lock cylinder and the car will not start. please help
