jessica 123
Posts posted by jessica 123
thank you for al of your help. I figured out the problem, the ignition switch was bad and the fuel pump sending unit is fried. Do you know where I can find parts?
oh and I am trying to replace the ignition relay but I cant seem to get the old one out, is it screwed in? of does it clip onto a bracket?
ok so I tried to jump the starter while turning the key and the starter turns over but the the motor will not and I tried starting the car in neutral but nothing happened, I tried to locate the the two black plugs that you were referring to but im not sure where they would be.
I apologize I worded that wrong. the starter and the motor crank but the car does not start. thank you all for your suggestions I will try your suggestions tonight when I get home. thank, you again
ignition switch? where would I find that? Its automatic, and it does try to start but will not.
yes everything electrical works, and the ground wire is connected.
it will not do anything. I turn the key and the lights turn on but thats it, the starter cranks if I jump it with a screwdriver.
I have replaced, the starter, fuel pump and ignition lock cylinder and the car will not start. please help
94 subaru impreza will not start please help
Posted
ok thank you all so much. have a nice day
