U.S. model equivalent of 2004 Impreza 15I for parts
diga replied to dzakh224's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry http://opposedforces.com. There is possiblity to look if particular part used for other subaru models (US and European but no Japanese).
Canadian Outback metrics converted to US standard in displays
diga replied to Ecappler's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSSM - Subaru Select Monitor
iPod connection for '05 Outback
diga replied to CPAScott's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIf your stereo has connection to CD changer there should be line in pins which you can use to connect your iPod (any MP3 player). But for this definitely you need a shop.
HELP! Trying to Remove Door Panel on '00 Outback Sedan
diga replied to 1075's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOne more screw is behind of windows control switches. I have taken out the control using wide thin screw driver.
Service Manuals and problem
diga replied to Rockbolt's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSubaru Factory Service Manual at: http://techinfo.subaru.com/html/index.jsp Regards, diga
windshield wiper mist function
diga replied to paule2222's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe icon of spraying is for rear window, I guess, if the same idea of multi switch is used in Forester as in Legacy. diga
Starting problem
diga replied to dumbs's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXYes, it should. At least it helped for me with the same symptoms of (not) starting. Egidijus
new struts
diga replied to bridorf's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWhen I was replacing back struts of my '94 Legacy II I noticed that original ones were KYB. I have replaced it with Bilstein struts, because of availability and price.
Dashboard Help
diga replied to berlin71's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXNever seen 91 Legacy dashboard connectors but for my 94 Legacy II I have used plug where it fits "technology" because all conectors has different shape. ------ Egidijus Subaru Legacy II '94
High Speed Idle
diga replied to cx20's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXTry to use this info: http://www.geocities.com/kuleshoff/IAC.htm But I do not know is it correct or not. I have not tried yet. Egidijus Subaru Legacy '94
diga
