Napzed
  1. using a multi meter i checked all the wires from the from the large connector to the solenoids jacks inside of the pan.... i got continuity for every wire on every pin..... ok hear this... when i start the car in park to reverse the light is stable.. as i touch the peddle like increase the rpm a little ... the light starts to blink......
  2. yes i did... its ok... now if the transmission is out of field safe mode... i can shake up all the wiring to and from the transmission and nothing happends the light remains stable. when i cross 140kmh the light starts to blink and its on safe mode once more.
  3. Good Brothers have a problem with my transmission ... now.... no hand held ODB was able to connect to the TCU..... I manually checked the problem by using the power light flashes to determine the trouble code... the code responded was the line pressure duty solenoid... i replaced that solenoid and the same problem arised . i maunally reset the tcu and ECU via battery pole etc...... the same code keep repeating saying it is line pressure duty solenoid. yes the transmission is in field safe mode. now if i start the car... while tumbling just before the engine starts i put it in reverse and the light stabilizes and its out of field safe mode. if i switch off and start back its good... but if i leave it off over 5 mins .. start back the power light continues to flash and transmission is in field safe mode.... what do you professionals think is the problem?
  4. my assumption is... its a issue with the innner harness . the harness of the transmission are all good. I did a continuity test from the pins to the soleniods.
  5. question is there a diode circuit in the transmission harness?
  6. ok... i think its a electrical problem.. i started my car today and it worked fine.. no problems and the power light remained on ...no noise and gears changed correctly and smoothe... . as i switched off and start back .. once again the light flashes :/ and back to field safe mode.. possible reasons/??? TCU needs to change?? harness break contact ?? no current to TCU?? poor Grounding? ???
  7. Hello good day... i have a 2000 forester with original transmission. The problem i got is that my power light flashes non stop and the transmission in is field safe mode where it shift from 1st to 3rd. i had all the solenoids checked out and my TCU refuses to connect to the OBD11 ... my transmission also makes a rattling noise which increses with RPM. any help would be greatfull
