Posts posted by BirdLoyale93
Thanks Dave!
Sorry for the incredibly late reply. I ended up taking her in to my mechanic.
It ended up being a loose connection inside of the firewall.
All is well now. No issues since.
Okay... I've got my oil pump off my EA82, and have my new O-rings, and the shaft seal...
Any advice on removing the front pulley bolt to access the shaft seal? I'm hesitant because I don't want to damage the rotor.
Thanks guys!
Thanks Rust!
If anyone is in the Oklahoma area... This is worth checking out. Wish I had a space to work on this one.
http://tulsa.craigslist.org/cto/5078955661.html
This 1993 Loyale was posted on CL... The owner said that it had a blown head gasket.
He was taking it to the scrap yard the next day... My friend and I ended up going that night to pay for it. ($350)
The storms here in Oklahoma were too intense to go over everything with the car... We ended up jumping it, and taking it around the block 4 times until it slowly started to overheat...
My friend and I went back a couple of days later to replace the battery and see what we were up against...
To my surprise it was just the lack of coolant in the radiator and a small leak in the lower hose!!!
This baby hasn't overheated since, and is running like a champ!!!
This is a great thread! Can't wait to see more!
- 2
Thanks guys! I'll start running through all of these! I'll let you know what I come across!
The coil bracket is connected.
Changed out my spark plugs last night.
Could it be something as simple as the spark plug wires?!
The other night I drove my (93' Subaru Loyale 5 Speed Manual Wagon 1.8 EA82) for about 2 hours while it was raining out. AC on the entire time. The next day I went to start her up... Nothing It just cranks, and will
not start...
Here is a list of everything I have tried so far:
Battery: good (tried jumping with my other Subie)
Alternator: good
Starter: good (clicks everytime I turn the ignition key)
Spark Test: No spark even after I put a new distributor rotor on... I'm confused about timing... any tips would help.
Distributor Rotor: I've put a new one on. I also checked to see if it was spinning when I cranked the motor to make sure it wasn't a timing belt issue.
Ignition coil: good (also put a new one on) Still no spark...
Distributor Cap: This is what I'll be changing out today... Hoping this gets a spark.
If i'm missing anything please help inform me!
I'm new to this so forgive me if some of this doesn't make sense. Any tips would help! Thanks!
not start...
Alternator: goodStarter: good (clicks everytime I turn the ignition key)
EA82 Oil Pump Shaft Seal
Posted
