corlitoa
Posts posted by corlitoa
Ok that's the first thing i did i checked the atf flyid and is ok is full and fresh it only engages in 1 and 2 and its like wen i put it in 2 is in 2 it dont go to 1 and then 2 is like manualy there but its slipping on 3 and 4 at low sppeds
No no leak in the trany
Well the trasmisión fluid is goot i changed it 4 months ago the light for the transmission temperature does not como on. Well i dont think is electrical because it doesn't engage in drive and wen i go true the gears manually it work but is slipping on 3 gear up untill it gets up to speed and dont slip no more
Hi guys i need some help with my 95 legacy lsi my atomatic transmission is not working properly when i put it on D is like if the trany is in neutral and on 3 gear is the same but wen i pu it on 2 or 1 it engages and i have to manually change the gears and at low sppeds the trany feels like is slipping reverse works and on the highway it works fine i just dont understand why wen i put it on drive it feels like in neutral
I need some help with this i just want to know if i have to get a new trany thanks
Hi guys i need some help with my 95 legacy lsi my atomatic transmission is not working properly when i put it on D is like if the trany is in neutral and on 3 gear is the same but wen i pu it on 2 or 1 it engages and i have to manually change the gears and at low sppeds the trany feels like is slipping reverse works and on the highway it works fine c
95 legacy transmission problem
Posted
Ok i didn't know the car had to be on i check it with the car off ????????
