johnvaudo
Everything posted by johnvaudo
  1. Along these same lines My speedo quit. Odometer and Tach still functioning is he guage bad or the Sensor? enquiring minds wanna know
  2. having an issue and I need some help. My 98 legacy cut off the other day. I checked the fuel pump it is ok, I checked the ignition coil it is ok but not appearing to get spark when I pull the #1 plug and ground the tip. I replaced the Ign Coil and got the same results. not sure where to look from here. it turns and turns but does not catch and run. HELP PLEASE!!!!!
  3. WOW thanks for the insight I was a Mech in the National Guard and had some that bad never thought I would run in to something this bad
  4. johnvaudo posted a topic in Shop Talk
    ok here is my situation. drivers side front outer CV joint has blown out. Axle nut appears to be over torqued or seized. have tried impact wrench not success, have used a torque wrench set in excess of 200 ft/lbs. broke the torque wrench. have soaked it all day with WD-40 have tried bouncing ( I am 200#) on a 24" 1/2" drive Breaker bar NOTHING!!!! Can use some serious advice can't replace the half shaft until I get this bloody nut off. Thanks John
