Stoc1173
Everything posted by Stoc1173
  1. Thanks for the tip. I pulled the whole thing apart, inspected every wire and connection and found nothing that raised suspicion. then I pulled all the relays, reconnected the negative battery terminal and started the car. The fuse was still good. the instant I hit a/c it blew even with the relays were still out!. I'm pulling my hair out. Could a bad controller cause this? I have a different one coming in any day now. Separately, I replaced the relays, pulled the fuse, jumped the compressor to the battery and it blew cool wonderful a/c through the vents even with the fuse removed.
  2. I've been fighting my a/c for a while now. Finally it quit. Everything checks out including pressure switches, relays, clutch ... I found the a/c 10A fuse blown, replaced it and it immediately blew again. Tried a 20A fuse, Blew! Jumped the a/c clutch to the battery through an ammeter, Works fine, draws less than 3 Amps. Where do I go from here?
  3. Someone suggested that a bad evaprorator thermo switch could be causing the issue. Any comments on this? Basically my a/c just doesn't work, fans don't turn on, nothing cycles nada! It was actuating ocaisionally with lots of repeat button pushing but I can't get that far now. I have a used controller coming in a few days. Assumming I can get it installed without destroying the bezel, we'll see what happens.
  4. I have a Haynes manual. Not too helpful. I'll check out the online version if I can find it. The Bezel extends around the instrumental cluster.
  5. Thanks, I'm still not sure how to get the trim bezel off. Where are the screws. Do I need to pry off snaps etc. Just a little more help please?
  6. Finally got on beergarage. Not what I want. I just want to replace the controller.
  7. I can't seem to open beergarage.com. I'll try later. I just want to remove and replace the a/c heater control unit. I actually would prefer a way to bypass the a/c turn-on functionality since I've been fighting an intermittant a/c for years now. I'm ready to sell an otherwise great '92 subie. I'm still not getting auto-spell corrections. Help please
  8. Need instructions on removing and replacing the A/C control unit on a 1992 Legacy AWD wagon 5-sp. I think everything else has been checked out including jumping the pressure sensors, directly powering the compressor, and checking all fuses and relays. The A/C works intermittantly. I had a shop replace the original control unit with a recycled one recently with no improvement. However, I disassembled the one taken out and found a blown diode in the circuit board. There is a bunch of them in there, just one bad apple! I plan to rebuild one good one from the 2 and reinstall it, but the shop has already charged me $260 for R&R and I'm not ready to fork out the same again. Alternately, I'd be happy with a manual toggle switch and bypass the whole unit, but I wouldn't know where to begin. Any help from my Subie brothers would be appreciated. p.s. how do you get the spell check to work on posts?
  9. Can't get new timing belt to fit
