puckchaser
  1. Thanks. I played around with the control and the only action that hits the vacuum switch is if A/C is set to MAX. Guess, I'll have to poke around and see if I can find the tubes in the dash.
  2. We got our 86 Brat a few weeks ago and the the previous owner said the climate control didnt work, pulled it out and and gave us a junkyard replacement he hadnt installed. His replacement has a few cut off vacuum hoses, but I cant see any vacuum hoses in the dash. In addition, I read in another thread that someone said the ea81 didnt use vacuum for heat/defrost switches. Can someone confirm? If so, would this make my replacement unit a no-go in my Brat? Thanks for any and all help!
  3. Jonas - I have an 86 Brat and am having headlight issues. The driver side high and low beams work fine, the passenger side has dim low and no high. I was looking at the wiring harness you posted and have one question.. where does it plug into to get power? I think I've located the relays for the headlights ( two silver cylinders to the right of the fuse panel under the dash), would this harness just replace the existing relays? or am i missing something? Appreciate any and all help! thanks. :lee
