The Awesome *NEWER* Generation Picture Thread
pzookey replied to Red92's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXA couple of 97 Outbacks Daughters 97 and the 98 parts car that donated its transmission and later its engine. 98's leather seats are in the garage waiting to go in my 97.
97 Outback 5 speed, First, second and fifth gear hard to find.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts been a couple weeks and the shifter is still nice and tight. Easy to shift and no guess work trying to find the right gear. Shifter stays right where you put it. Easy enough to replace everything. Should have done it a long time ago.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks again Fairtax and everyone else. The linkage came out easily. A roll pin punch made quick work of it. I took the extra 10 minutes and pulled the support for the trans mount. Gave me a straight shot to the roll pin. I found going back together to be more off a pain than coming apart. but then My big hands don't like fitting in those small places.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI love the way the shifter stays in place now instead of flopping around....lol
post 04 subarus are Junk...buyers beware
pzookey replied to logic23's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI used to work where the AC compressors are made. It is a Toyota Denso joint venture and has been for quite a few years. They have some issues.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXRebuilt the shifter linkage today. This is the shortest throw shifter I have ever driven and I had a short throw Hurst shifter in a Beetle I owned many years ago. All the bushings from Subaru were Urethane and fit perfectly. The new large bushing I got from Amazon and was a perfect fit. I did have one issue. I went to test drive and my hand hit the dash going into first. The shifter had spun around when I was underneath and I bolted it back in that way. Pulled the bolt spun the shifter and back to working. The return spring was there and in good shape so it got re-used.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWell the post office apparently had a delay in their shipping. The parts were supposed to be delivered yesterday but according to the tracking number they are still in Atlanta. That pushes the work back to next week.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXKudos to subarupartsandaccessories.com. When I ordered the parts online from the diagram it showed the bushings as separate pieces from the joint. I ordered them that way. Yesterday I received an email informing me that the joint came with the bushings already installed and asking if I wanted to cancel and get a refund for the two bushings that I wouldn't need. Today I got the refund and the tracking number for the rest of the parts. Most places would have not said a word and just shipped what was ordered. I appreciate the time taken and I saved $23 int he process.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXLucked out with info from the outback forum. I have ordered a urethane bushing from Amazon that someone else used in a 97 outback. At $23 it was half the price of the original. It should get here at the same time as the rest of the parts. I forgot to order the return spring but I am hoping my new local dealer has one in stock or can get it before next weekend.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXOk, just got in the house from an oil change and new pressure sender on my Dodge and checking out the shifter on the Outback. I found just about every bushing is worn out. I am glad I ordered just about every bushing. I may have to get a spring and I am trying to locate the right big bushing aftermarket as Subaru want $46 just for it. I may drop the cross member to make it easier to get to everything. Fairtax4me, thanks for mentioning the #21 bushing. It has quite a bit of vertical slop in it. Good thing is that it does not look very rusty anywhere.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI found the #17 on a Subaru parts page but at 46 buck for one bushing I think I am going with an aftermarket urathane one provided I can find the right one.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd yes fairtax I did order the #21 bushing. There was no part number listed for 17 but I may have found a urathane replacement. Just have to confirm it.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXJust ordered the parts from a Subaru dealer in CT as they were a lot cheaper than the locals. Next weekend should be a good time to work on it.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a brand new local dealer.. I usually order from one closer to Atlanta but I was a little annoyed when they charged me for shipping twice but everything was shipped in one USPS flat Rate box.
pzookey replied to pzookey's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks for the big picture. I had found it on the Subaru parts site but the picture was small and hard to read the part numbers. It sounds like you have run into this before.... I have a set of roll pin punches and a gallon of PB so that part is good. Time to get the parts located and ordered, A subaru dealer up north had the $60 joint on sale for 46 bucks. I will be pricing and ordering tomorrow. Thanks again.
