scoobydoo wagon
Everything posted by scoobydoo wagon
  1. thanks guys!! After thinking about it and testing the AC i think I will junk the whole thing. Weight loss will help a tiny bit on mpg and it will give me a bit more room in the engine bay to change plugs and stuff.
  2. Hey everyone Ive got a 2002 Legacy wagon 2.5l auto. It has AC which I never use up here in Canada. I was wondering if it would improve the mpg and zippiness if I disconnected the drive belt for the compressor. Im tempted to remove the entire unit for the weight but Im not sure I want to put in the effort of redoing the heater unit and rad etc. Also I might sell the car in the spring and having AC would help (altho I never understand that here in sunny ole Canada lol). The belt isnt in perfect shape so Im tempted to just slice it off with a box cutter but is there something Im not considering here? Thoughts?
  3. Hey guys, Thanks Crazyhorse. Your suggestion is just what im starting to think...but not a kink in the pipe. How about a plugged cat? So I have located an intake manifold leak and put a new gasket on it. However the issue is worse than ever. I have noticed a rotten egg smell. And my understanding is that a plugged cat could blow out the intake gasket which would lead to the surging and stumbling ive seen. Now the gasket is replaced the surging is gone but it is just missfiring like crazy. It wont run at all. So I am going to crawl under the car (and it is cold as hell here in Nova Scotia) and try to drop out the 2 cat pipe just behind the Y-pipe coming off the engine to see if theres evidence of the cat gone bad. Before i try to get the crispy rusted hardware out on the freezing ground what do you guys think? Am i crazy or could this be a likely/possible cause?
  4. Thanks so much John. Im trying to get my hands on a wrecking yard one as we speak. They are hard to come by up here in Nova Scotia. At least I can eliminate that at hopefully not too much cost. My greatest fear is it is some electronic fuel control issue. I started thinking about O-2 sensors or PCV valves and such but Im way over my head there. And I wasnt kidding about being desperate, my wife is seriously ill and i need the car to take her to hospital and our kid to school and silly little details like groceries and work. If I cant find a solution fast Im in deep s**t. I will also check my battery connections. I very much appreciate your advice. I havent had much good luck in the last year so I really appreciate you taking the time to write me back.
  5. Hey there everyone!! Im a long time soob owner but new poster in need of some assistance. I have a 2002 Legacy wagon that got rear ended about 3 weeks ago. The physical damage is pretty minor but when I started the car to drive away from the accident scene I immediately noticed there was a driveability issue which has got progressively worse. When driving it now "stutters" and loses power. If you ease off on the gas and then press it again it goes back to normal. It also now has sudden wild tach fluctuations when it is running in idle/park. And it is getting worse to the point now where its not safe to drive. I initially thought perhaps some crud and varnish got knocked off the tank due to the collision so I changed the fuel filter but that hasnt changed anything. Even though its a zero fault accident the insurance people have refused to accept that this is due to the accident (and maybe it isnt but it wasnt like this before the collision) and claimed because of the age (2002) that its unrelated. I largely dont care about the cause but I need to fix this and I am poor so I cant afford to take it and spend $150 for a diagnostic that the local shop has pointed out might not pinpoint the problem. I am wondering if anyone else with this model (or any other) has experienced this problem and what you "guys" could suggest. I am wondering if the fuel pump/ sending unit in the rear tank, which is original/old has given up the ghost after the blow from the other car. Since a replacement pump here in Canada is $400 and the entire sending unit/pump is $600 I cant afford to swap it out to see if that fixes it. So does anyone have any thoughts about how to proceed? I dont care what the issue is (insurance wont pay anyway) but i need to see if i can come up with a fix on my own. This is my only vehicle and I have a family...we NEED this car. Any and all suggestions welcome. Many thanks!!
