Everything posted by Norcalsubi
Help torque converter is stuck on shaft 2004 impreza
Norcalsubi replied to Norcalsubi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThanks a again all
Norcalsubi replied to Norcalsubi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAnd thanks a lot to everyone
Norcalsubi replied to Norcalsubi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXGood diff is in car that I squished the trans pump in just have to swap trans to that one, can I leave diff in place while I remove tranny
Norcalsubi replied to Norcalsubi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXParts car right front wheel was banging and hopping,bad front diff,I hope. am I assuming the trans is behind front diff is that correct,so pull trans and leave diff.
Norcalsubi replied to Norcalsubi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI have a donor car with a good trans , but a bad transaxle ,the trans axle is separate from tranny correct, thanks to all for answering
Norcalsubi replied to Norcalsubi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXHave a parts car with tranny but had some front wheel slam and hop was told transaxle so I'd assume that's in front of transmission and tranny would be fine I'd hope , also did I f#@# up the trans pump bye not leaving tc on trans and or not attaching it to tranny first on install
Norcalsubi replied to Norcalsubi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAny way to release the shaft from transmission, been pulling yanking swearing have replacement parts , everything went together good but I had tc on engine , I think that's were I went wrong
Norcalsubi replied to Norcalsubi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlso tc wiggles and moves on trans shaft
Norcalsubi replied to Norcalsubi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXWon't move yes
Norcalsubi replied to Norcalsubi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXShifts but won't go into gear ,engine went together fine no grunting, I'm thinking the torque converter on new engine could be bad, also how do u get to clip , and thank u
Please help swapped engine and wouldn't go in gear removed engine now torque converter is stuck on transmission shaft nothing will release how do I remove it's an automatic
