Norcalsubi
Everything posted by Norcalsubi
  1. Good diff is in car that I squished the trans pump in just have to swap trans to that one, can I leave diff in place while I remove tranny
  2. Parts car right front wheel was banging and hopping,bad front diff,I hope. am I assuming the trans is behind front diff is that correct,so pull trans and leave diff.
  3. I have a donor car with a good trans , but a bad transaxle ,the trans axle is separate from tranny correct, thanks to all for answering
  4. I have a donor car with a good trans , but a bad transaxle ,the trans axle is separate from tranny correct, thanks to all for answering
  5. Have a parts car with tranny but had some front wheel slam and hop was told transaxle so I'd assume that's in front of transmission and tranny would be fine I'd hope , also did I f#@# up the trans pump bye not leaving tc on trans and or not attaching it to tranny first on install
  6. Have a parts car with tranny but had some front wheel slam and hop was told transaxle so I'd assume that's in front of transmission and tranny would be fine I'd hope , also did I f#@# up the trans pump bye not leaving tc on trans and or not attaching it to tranny first on install
  7. Any way to release the shaft from transmission, been pulling yanking swearing have replacement parts , everything went together good but I had tc on engine , I think that's were I went wrong
  8. Shifts but won't go into gear ,engine went together fine no grunting, I'm thinking the torque converter on new engine could be bad, also how do u get to clip , and thank u
  9. Please help swapped engine and wouldn't go in gear removed engine now torque converter is stuck on transmission shaft nothing will release how do I remove it's an automatic
