Masai
Everything posted by Masai
  1. would you shrare it with us i too have EA82T 1987 model whose wirining needs to be redone.thanks
  2. on the ECM which is pin 1 and what is the order. Thank you
  3. Thank you, very clear am most grateful. Kindly similarly illustrate wires to the igniter and the ignition coil as I have several wires whose destination is not clear. Am attaching pictures for clarity. Also find attached a unit under the front left side seat, I don't seem to know it neither its function.
  4. how would one buy it for parts, I mean the ea82t one
  5. the coil is tested okay, . May know where you sent the diagrams please
  6. I am most grateful. As for the rats I have biologically allowed a control and eliminate friend to represenent me and the subie called Mr cat. thanks
  7. my distributor is xxxx450 it does not have the vacuum advance unit my ecm is 4 plug
  8. hello Steptoe sorry I shelved the recovery of my Subaru to work on another project out of town. am now back This is a Subaru leone 1.8 turbo EA82T engine. The ECM is four plug. Rats chewed up wires and pipes around the Distributor,the ignition coil, and the igniter. I need help identifying which wire connects which terminal so I can crank the engine. much thanks
  9. yes those, and particularly the one that conducts the signal from the engine control unit to the ignition or igniter
  10. sorry about the use of words and thanks, I believe the Ignition control module (ICM) and igniter refer to the same thing. My car Vin AL7.011866 is an 87 model, the igniter is on the coil bracket, so I believe the system should basically be the same with little variation. I need (1) to identify the pulse wire from the control unit under the steering to the igniter at the coil.(2) the wires from the ignition coil to the igniter and tachometer.
  11. thanks, I will appreciate your help, especially with wires and pins/ connectors from the ignition module to the ignition coil and from the module to Ecu.
  12. kindly this is my EA82T ignition section which has been messed up, I am trying to reconnect the wires from the module. There is the Blue and Black/white wire pair towards the distributor, and the Black white Wire and Black red pair directly under the ignition coil. The car is Subaru Leone 1.8T 1987 model, and the wiring diagram isn't clear on this Thanks edsaisam@yahoo.com
