Hello All -
My first post to the forum. I am trying to diagnose a growling noise that I get when accelerating, most prominent in 3-5 gears, over 35 mph. I have read a lot of posts on the web but am sort of confused by conflicting write-ups.
Symptoms:
When I am accelerating at higher speeds, I get a growling sound in addition to the engine rpms going up. This a deep sounding grrrrr, coming from the front end. If I let my foot off the accelerator, the sounds stops. If I tap the accelerator the sounds will occur again, with every push there is a corresponding grrr... Sound does not seem to change if I am turning in either direction.
Some things I have read say that this may be a wheel bearing issue, but then why would it go away when not accelerating. Wouldn't the wheel bearing make noise if the wheel is simply turning? I have also read and saw some youtube vids where they say this would be a high pitched whir sound.  Mine is very much a low pitched grrrr sound.
I also thought perhaps it might be the cv joint and front passenger axle. Here, I should say my front passenger axle boot is torn and there is some play in the front passenger axle. maybe 2-3 mms of pull on it at the wheel. Not near the diff.
Lastly I have read that perhaps my issue is the front differential, which I am hoping it isn't as that seems to be the most expensive. Is there some way to determine what the front differential issues sound like?
Any thoughts or advice are highly appreciated.
I am mainly stumped one the type of noise sound and when it happens. It is most definitely most pronounce the faster I go. Rarely heard lower then 30mph. Only heard on acceleration. Turning in either direction seems to make no difference.
I am planning on replacing the passenger front axle to cure the torn boot issue and movement. I guess that is the best place to start, but if that doesn't seem to sounds like  why this noise would occur. please let me know...
cheers,
Steff
