Everything posted by RCWD21
EJ22 Coolant reservoir bubbles
I think this is my first post, can't really remember seeing as I already had an account in here and somehow didn't remember it but here's my problem. It's a 98 impreza wagon with a SOHC 2.2 that last night I smelt coolant coming from the front of the car. I popped the hood and noticed that the area around the resovoir was wet from coolant. Since it was still hot I left it for this morning. *As an additional note I replacemed the radiator back in June or july before my trip to ohio from southern north carolina. This issue has just presented itself right when I'm about the sell the car in a few weeks to a buddy of mine so you can imagine my aggravation. This morning I popped the cap off and coolant was really low to the point that I couldn't see any in the tubes. I filled it up and started it up so it could run and warm up. It overflowed just and little bit out of the radiator and I thought it was good to go, then I looked over at the resovoir and noticed it was below the low mark by maybe a half an inch. I filled it up just above the full mark. I let it run with the cap off for a while until the temp gauge was in the middle where it normally is. Drove about 3 miles got home and checked it again. Noticed the resovoir was about double of what I put in it before the drive. Now I get intermittent bubbles in the resovoir sometimes more extreme than others. It hasn't overflowed on me today as it seems to have found a level it has stayed at. Here's where I get concerned though, the upper hose feels like it's completely empty sometimes and with a hot engine I can remove the cap within probably 10 minutes after cutting the car off. I've read that HG failures on 2.2s are very rare and that it is more than likely a cap issue but with the bubbles and the lowering coolant level in the radiator I fear that it may in fact be head gaskets. The car has never overheated on me and always has good heat where it will literally cook you out of the car on full blast. Could this be a bad cap issue? If so where is the air coming from while it's running? The cap appears to be in good condition and the seals are clean and crack free. Would a compression test tell me anything? And is it possible that there's still just a good bit of air in the system from having the radiator replaced and block flushe'd back in June or july? Anyone that could help me on this would really make my day..
98 impreza wagon front end whine
RCWD21 replied to RCWD21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm going to get a price of all the needed parts and weigh that against a used transmission. The thing holding me off from a used transmission is this whole situation being a problem in the new one or it starting shortly after the warranty runs out.
RCWD21 replied to RCWD21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI got all the correct fluids in the correct place. When I drained the front diff yesterday the fluid was very thin. I also checked the atf to see the color off it and it didn't smell like gear oil until I changed the front diff fluid yesterday. I've read that the seal on the pinion shaft rarely fails and the orings on the torque converter tube are more likely. But with a bad bearing allowing the front pinion shaft to walk I wouldn't be suprised if it actually is the pinion seal. I've found diagrams with the part numbers finally and just the front bearing is $165. I'm still getting part numbers and prices but the diagrams really help.
RCWD21 replied to RCWD21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlright well I came home to check the atf level and it smells like gear oil... so what are my options now? Rebuild the front diff? Or would just finding a used transmission be the easiest option? I don't really have the money or time to do either.. Does anyone have PART NUMBERS for the pinion bearings and the front pinion shaft seal???
RCWD21 replied to RCWD21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI'm probably over thinking this but just to clear it up, the pinion shaft lives in ATF right? I would assume so, I'm still learning about the 4eat. I'm much more familiar with the RE4R01A transmissions.
RCWD21 replied to RCWD21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI don't understand what you just said.. as for the fsm I'll look into it more today.
RCWD21 replied to RCWD21's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXAlright, more info on the situation. I took the same route as in my first post but this time with the FWD fuse installed. The noise was still there but it was slightly quieter but more high pitched almost to the point that I couldn't really hear it over the normal road noise. With the way these cars are the noise seems to echo all throughout the cabin so I would assume that it's a vabrational noise due to a bad bearing which is what I've basically come to conclude that it is. Now I have one huge question that I can't seem to find the answer to. Does anyone have the part number for the front front pinion shaft bearing? I found the subaru number but haven't looked into it much as to something that will cross over etc. I did look at the gears up through the drain hole earlier during the fluid change and the teeth on the gears looked fine to me but I'm not 100% sure. I'm hoping I've caught the problem soon enough since the noise is still a whine and not a grinding sound and simply replacing the bearing (and also giving me an opportunity to clean and reseal the engine) will take care of the problem. And one last question, does anyone know where I could get a service manual for this car/ transmission?
This is my first post here and also my first subaru. I really enjoy this car a lot more than I thought I would. It's a 1998 Subaru Impreza L Wagon with the ej22. It's got a very small amount of rust and a few dings from someone shooting it with a bb gun but that fix is for later. My big issue right now is a classic noise front end. At first I thought it was the rear wheel bearings from what I have already read (got it inspected 5/31/16 and they said there was no play in the rear wheels). I put the FWD fuse in and the noise got slightly quieter like there was less load on something. I changel the front (it was super thin almost like penzoil syncromesh and fairly dark) and rear differential (80/90w but dark) fluid today with some fresh 80/90w and some Hyper lube oil additive just because I had a half bottle laying around. Went around the block and everything seemed ok. Went for a 10 mile test drive and around 5 or 6 miles in the noise got louder and higher pitched than before. Strangely since the fluid change the noise which I thought was coming from the rear has become more pronounced basically right between the front seats maybe a little more under the shift lever. The noise sounds like straight cut gears and it is most prominent when cruising and light throttle while at speed and also while slowing down/ coasting. It's the loudest above about 30mph and will sometimes almost completely go away at random speeds (it went away for a few seconds with 3 people in the car and going over a bridge with the body moving up and down). It's becoming somewhat worrying as I have a trip to Ohio coming up as soon as funds and time allow (1400 mile round trip) and I want this thing to get there and back no problem. I haven't checked for much besides changing the differential fluids and driving around trying to localize the problem. There are very few subarus in the junkyards near me and what I've found online near me is pretty expensive and the condition is sometimes questionable. I'm very mechanically inclined and have access to almost $10k worth of snap on tools and pretty much everything I've ever needed to do my own work. Does anyone have any idea where to look or go next? This noise doesn't sound like a wheel bearing or grinding gears. It sounds like a gear whine that will sometimes go away.
