Climate Control Issue!
ethmail11 replied to ethmail11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXi pulled each one did a visual inspection... I'm going to do the same but test them as well!
ethmail11 replied to ethmail11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXIts a Legacy 2012 and i checked all the fuses and all seems fine (both by the engine and on the drivers side!) I probably spent an hour just looking for an unplugged cable/ broken one but i just cant seem to find one! any help would be nice!
ethmail11 replied to ethmail11's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXI just wanted to thank you for the fast response! anyways its a subaru legacy 2012! and I forgot to include this but i have dissembled the car and it seems as if everything is plugged in. I probably spent an hour just looking for an unplugged cable/ broken one but i just cant seem to find one! and i also forgot to mention that i did go through and look at every fuse in the car and by the engine and all were fine!
So the other day I was installing a new car stereo in the car as I wanted to change all the stock speakers as well as add some bluetooth functionality to the car. After installing all of the door speakers, I installed some tweeters into the stock location (in the dash). I had to shove them up into the location as did not want to remove the whole dash. Now heres the issue... After installing everything correctly, my climate control will not work at all! The only thing that works is adjusting the blower! I cant turn on the A/C,change where it comes out, or turn on the defrost! When I Push the button none of the lights come on only the illumination lights come on at night! this all started happening after I installed the tweeters as I had the stereo in for awhile before this happened. So I'm wondering if I bumped/broke a cable or something. I also should mention that my tire pressure light is on even though all my tires are filled correctly and my cruise control turns on but I am unable to set it! Any help would be nice!
ethmail11
