go giants
  1. Ok its possible i will try to check all of those things asap thanks again for all your help
  2. Ok i looked and all grounds are attached to engine and body still have codes active
  3. I used harnes and intake from old motor and plugged egr port so thats why its confusing but i will double ck when i get hm this weekend thanks again
  4. Thanks for responses i will check wireing thos weekend and see if it makes a difference
  5. I did change cam and crank sprocket i mean car runs good except dor oil leak i cant find source of as yet but i need to get car inspectef i did replace sownstream 02 but still got code p0136
  6. I recently changed engines took automatic from 2003 subaru and installed in my 2000 outback manual used my intale from old engine the are both 2.5 engine runs great but have codes p0500,p0122,p1100,p1101,p0136,p0131,p0132,p0325,and p0122 any suggestion should i have changed ecm also
