Bratastick
Everything posted by Bratastick
shifter fix for 4 speed-- DAMN PHOTOBUCKET
Bratastick replied to Bratastick's topic in Old Gen.: 80's GL/DL/XT/Loyales...
doesn't work for me, I get the same stupid placeholder image. -
How do you find Brat rear seats..
Bratastick replied to Paperscale's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I've had the same trouble. Ended up buying a whole parts Brat for the seats.... and a few other bits. -
2nd generation brat roll bar
Bratastick replied to 65stangy's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I'm hoping this one will allow me to mount the jump seats. It looks like some I've seen in dealer brochures. I've also got a brush bar that looks similar to the dealer brochures, it does not go around the headlights, just the center. -
Spare tire options after 6 lug hub conversion?
Yes it's a Brat. I've got 14" wheels with 195/70 tires, should have specified that originally. I tried one today and it won't even squeeze even part of the way in. Does the full size 13" actually fit under the hood. I haven't tried one of those. I do have the original doughnut. Guess I could drill the wheel on the doughnut and use it. -
Just doing a small 2" lift but will need to extend the steering shaft. I've looked around though my scrap pile but really haven't come across anything that would work well. This is on an 82 Brat. The shaft is bigger around at the top, just shy of 5/8*. The lower is smaller, but doubt if there is enough clearance due to the axle. I'm thinking a tube to slip over each end and weld.
Betzi the rally wagon race Video
Bratastick replied to schwimmwagen's topic in Old Gen.: 80's GL/DL/XT/Loyales...
that's some white knuckle stuff right there, surprised they even know what the General Lee is in South Dakota, but on second thought that maybe only in North Dakota. -
what kind of muffler on 2gen brat?
If I were to need to pass emissions, which I'm not required to do, I'm thinking no converter is going to let my Weber conversion pass. It's likely this car will be driven less than 1000 miles annually. I do think your prescription for a high flow system is spot on. -
I guess I'm that guy that doesn't see the need for a catalytic converter. -
Need to get the exhaust reworked. Gonna have them cut out the catalytic converter and run a 2 inch pipe. I'm hoping they can reuse the original Y pipe. What kind of muffler would be good. Don't necessarily want anything really loud, but a little would be ok. I'm guessing the stock mufflers were pretty quiet.
The rats are in my brat!
wow, looks more like squirrels, they are rats too -
'85 BRAT fuel tank & sender
Bratastick replied to mhisstc's topic in Old Gen.: 80's GL/DL/XT/Loyales...
It's the Caswell Plating epoxy. I used it on another tank and really works well. You can order it direct or I think they sell it on Amazon. -
I've seen a few listed for sale on Facebook and maybe here. I've heard the station wagon tanks are the same. I had the same issue and in these parts old Subaru parts are hard to come by. I did this instead: http://www.ultimatesubaru.org/forum/topic/161908-anybody-ever-cut-open-their-fuel-tank/ -
BRAT fuel system issues
Bratastick replied to The Chariot's topic in Old Gen.: 80's GL/DL/XT/Loyales...
The return line inside my tank had pin holes in it at the top of the 180 degree bend. It would not have substituted for a supply line. Your tank is probably in better shape than mine was. -
I ended up having to use a drill bit to dig out part of the crap in there so there was no way air pressure would have done it. The return line is a lot smaller than the supply, but it may provide plenty of flow. -
I think it was just a build up of sediment over time. There was a lot of crap in the tank. The baffles had pretty much rusted away and all of that was on the bottom. The bottom of my tank was actually coated with a tar like substance. I think it was some sort of sealer from the factory. It was compromised so I had to remove it. I did a write up on my repair. The car had been sitting for an extended period of time, probably 20 years. http://www.ultimatesubaru.org/forum/topic/161908-anybody-ever-cut-open-their-fuel-tank/?hl=%2Bopen+%2Btank -
I could not get my fuel line to unstop even after cutting the tank open. There is one 90 degree bend and one 180 degree bend and the line was completely solid at the end where the sock was. The actual sock was fine, just the line was plugged. Ended up cutting the line and removing it, unplugging it then silver soldering it back in place. Don't think you could hurt anything with compressed air, maybe you will have success. You can see the pickup w/ sock if you remove the sender unit. -
post a photo or two
I'm thinking 3/16th
Brat barn find... now what to do first?
According to the guy I got the wheels from they came off his Dodge pickup that he bought new. They were dealer added wheels. -
Actually, yes. I think I updated the fuel tank rebuild on another thread, but I've also pulled off the old manifold and Carter carb and replaced with a Weber. Cleaned the interior so that you don't feel too bad about sitting in it any more. Drilled my hubs and drums to accept 6 lug wheels. Replaced an axle, all new brakes and master cyl. New windshield wiper blades! Dang, now I find that the wipers don't work. Adjusted the valves, they were pretty wide. Changed all the fluids and every hose. New waterpump and oil pump. Replaced the distributor, new cap, wires, plugs etc. Bought a parts Brat to scavenge some misc. parts from--- including jump seats!!. The main reason I bought it. Got new tires, 195/70-14 and some Dodge D50 alloys. Unfortunately the slight bit of offset difference is causing fender interference in the front so the next step is to install a small front lift. I have a 2" kit just haven't had a chance to get started. The engine purrs like a kitten. I have not gotten to drive it other than back and forth out the garage due to the tire rubbing issue, can't really make much of a turn. Got the carb and timing adjusted, the electric fan works good. Just can't wait to actually take it around the block. The only home run on the rusty parts Brat I bought would have been if it had been an A/C car, unfortunately it wasn't.
