outbackrally
Everything posted by outbackrally
  1. Will do. I believe they are factory as the dash has a subaru factory fog light switch on it. I'll test the current but I think it is likely the switch seeing as the light doesnt illuminate when the switch is depressed even though there is power through that purple wire.
  2. Just tested the wires leading to the switch, there is current to a purple wire (30v) and to a black wire( 10v) but there is no current when the switch is on. is it likely that the switch is fried somehow? the car has 109k on it if that helps.
  3. No, I wasn't sure what wires to test as the switch is a closed plastic unit.
  4. Yeah they worked this summer last time I used them then suddenly didn't. I've made sure that it wasn't that and the fuse was the next step in the chain as well as new bulbs but it still doesn't turn on, and i've exhausted my electrical knowledge.
  5. Hi, so my 2000 outback limited is having fog light issues. When I turn the fog light switch on, the indicator light doesn't turn on and the lights are receiving no voltage (tested with a voltmeter). I don't know all that much about wiring so any help would be appreciated but I did replace the fuse and it didn't help.
