gonzalezpereza
Everything posted by gonzalezpereza
  1. I have cleaned all the grounds with contact cleaner and added extra grounds to check but no luck. I have ordered a new coolant temp sensor and I will try with that, if it doesn't work I guess I will end up rewiring everything to check. I'll post what I find when I receive it.
  2. Is it possible to have the readings ok and still be the coolant temp sensor the problem?
  3. I have been checking the temperature and everything else with Freessm and romraider and all the readings seem fine, even the water coolant temperature. FreeSSM throws the code 22. Romraider reads a P0111 code, and a code P0336, with the P0111 code the check engine light does not light up. The teeth in the sprocket seem to be fine. I have tried changing the crankshaft position sensor with the one from a subaru impreza outback sport I have with no luck. The error P0336 only comes up with the new sensor, but the check engine light stays on showing code 22 on FreeSSM.
  4. Hello everyone, I have a 2000 Subaru Legacy Outback with a EJ251 engine that is giving me some trouble. I started getting a code 22 each once in a while with some noticiable knocks with the engine under load, it would occur on a slight hill with the engine between 2000 and 3000 rpms, after reving up the engine the code would clear after a few seconds. It would also show sometimes with the engine cold after starting the car for a few seconds, it would clear not much after. Since the head gaskets were starting to leak i decided to change them and clean the pistons and the combustion chamber. After putting everything back together I have found I still have the code, no more hesitation when driving or anything else. I have changed the knock sensor, map sensor, put new injectors, new pressure regulator, new oxygen sensor and I still get the code. With the new knock sensor it stays longer with the code while the engine is cold and comes on more often. ¿Any ideas on what could I do? I have also cleaned all the connections and checked all the service manual recommends. ¿Could it be that it is detecting the beginning of a rod knock? The engine sounds fine to me and it drives fine too, the only thing it shows is a very bad gas mileage.
