CopesLegacy
Everything posted by CopesLegacy
  1. Ok, yea I read about Trans-X in other forum posts on these 4EATs. Thanks, I'll look into that option with the pending fluid change I mentioned. 1 Lucky Texan, do you have any idea if the brake band could need adjustment based on my description of the problem? Thanks!
  2. Hello All, New to these forums and looking for some 4eat advice. I have a recently acquired a 1991 Subaru Legacy wagon with the automatic transmission (142,000 miles). After a week of local daily driving, I've noticed a couple things regarding the transmission. Most interested in thoughts on #2. 1) This week the 16-flashing POWER light deal on the dash happened. Went through the process to determine code...TCU code 22 - Atmospheric sensor. Unfortunately, not a solenoid that can be replaced from what I gather, but actually has to do with the ECU. Checked the OBDI engine codes, no corresponding ECU atmospheric sensor fault (would be code 45). After a full reset of the ECU/TCU (pulling fuse 14 from the driver side kick panel) this has gone away (for now). 2) However, despite the TCU POWER indicator not coming on after the reset, I am still experiencing my primary cause for concern. From a stop, upshift from 1-2 has a little "thud" (not too unusual for the 4EAT from what I gather). Then upshift from 2-3 is smooth, BUT, there is an acceleration lag after the shift before the car starts forward again (I have NOT let off the accelerator pedal at all). It doesn't last long, but it's obvious and annoying. It seems to become less pronounced the longer I drive the car. 3) Fluid looks brand new, reddish and clear, not burnt or brown looking at all. It is however above the high mark on the HOT side after driving the car and go through all the gears while on a level surface. Any thoughts on these issues, particularly #2? My plan is to drop the transmission pan, replace the filter, add new fluid, as well as replace the inline transmission filter located near the coolant reservoir. Could it be something to do with the brake band and if so, go tighter or looser? Is there cause for concern here? Thanks(!) in advance for your time and thoughts. Matt
