ickthoose
  1. Followed your advice and ordered the part from a dealer. Perfect fit, transmission is back together.
  2. I have a 2003 Forester 5 speed already out and split to replace the input shaft seal. My question is on the seal I received from Rock Auto. I've attached a picture of the two, the one on the left is the original. The one on the right came from Rock Auto. As you can see, the one from Rock Auto is half as wide. Does anyone have experience using their seal here? I've used other sized seals like this on other not so critical areas but it's a lot of work if I have to pull this back out. I was unable to find a conversion chart for National to NOK seals. Rock Auto says it's the correct one. My nearest Subaru dealer is 90 miles away so if I have to go, I'd like to go once. The National (Federal Mogul) part number is 222558. The rest of the seals I received for the axles and rear main look correct. My inclination is to send it back to Rock Auto and make the trip to the dealer. What are your thoughts? Also, where do you guys shop online for your Subaru parts? Thanks for your help.
