YaBoyKingsley
Everything posted by YaBoyKingsley
  1. Okay so I have quite a few spare ea71s for my 78 sema brat project and someone used the oil pan as a jack point and then only changed the oil pan and if that wasn’t bad enough the oil pick up tube got bent and someone tried to pry it out with a screwdriver and I tried to gently get it out and it’s starting to tear at the insert point it’s about halfway out but I’m afraid it might be beyond saving so my questions are do I separate the tube from the insert then try to pull the insert out separately and tig weld it back together later? and does anyone have a spare? thanks for the help in advance
  2. I actually have a lot of experience with a rotary and a buddy of mine just got a brat with a 13b rotary mounted and is working on the transadaptor but might change the transmission and rotarys are not terrible engines but you need to drive them or they go bad similar to a Porsche anyways best of luck to the project but I’m afraid my friend is one step ahead of you
  3. Thanks well I’ll play it safe
  4. Well I got a spare transmission and what if I where to strengthen the diff’s gears and make nice on all the seals do you think it would last any longer or should I play it safe
  5. If I take the front axles out of my brat (properly I won’t just pull them I know they hold the hubs in place) and if I put it in 4wd drive then would I have a rwd brat and would I be able to do donuts but more importantly would it be safe I’m trying to get this brat(1978) to sema 2019 all help would be appreciated if that wont work has anyone mates a rwd drive trani to a ea81(that’s whats going into it the ea71 is getting sold)
  6. Hey guys I had a few questions for the brat I’m having custom axles made and getting some classic jam rims but before I get the same size all around I was wondering what the limitations are for the brat (78-81) 4wd was my main question is why is it limited to 50mph because I was told depending one what the limitations where I could have a shop do some changes and get it to where it’s basically awd if not I still need to know because my boss(he does Porsche’s which are very different but he knows his motorsports and performance things) said if I wanted a rwd brat I could disconnect the front axles and leave it in rwd I plan on having this at sema in 2019 and have everything lined up thanks for the help in advance
  7. I was wondering if anyone knows what kinda carb I would need to get a turbo on I know I would need a blow through and I was wondering if anyone had experience (good or bad idea) thanks
  8. Anyone know how to lower a first gen brat I’m not looking to slam it but before I dish money on custom bags and coilovers and ideas or previous ways someone has low red that body style thanks in advance
  9. Would this drop in basically or would I need to change axles and other things
  10. I have a brat with a ea81 and I’m looking to make it awd if possible anyone know what transaxle I should look for Thanks and have a nice day
  11. Hey guys I’m looking of putting a better transaxle in my brat I have a ea81 and would prefer something that could use the same axles driveshaft and everything I would prefer Awd and a Manuel what would you guys recommend I look for thanks for the help in advance and have a nice day
  12. Yeah I found a way to convert the lug pattern pretty cheaply but know I just have to find 15” rims
  13. Hey guys I was having trouble finding the parts needed to convert a brat to 4 wheel disc and I’m looking to overhaul the entire brake system with a different lug pattern I’m looking for discs that will fit in 15” rims and preferably a more common lug pattern thanks guys sorry to have to ask twice
  14. Thanks for helping me with a lot of my questions I’ll be taking this route if I can
  15. What models has ea82s in them so I can get the parts of off one
  16. Hey guys I was wondering if I could convert my 78 Subaru Brat to all wheel disc to stop better and if I can get drilled and slotted discs that’s a bonus and some decent calipers I’m putting 15” rims so as long as they fit inside I’m cool with it thanks for your help
  17. Swapping a ej isn’t possible for me
  18. Hey guys I am building a ea81 and was told to use ea82 SPFI pistons while other people are telling me to use ea71 pistons and I was told to get a torque grind cam and a get a ea82 intake i wanted to know Where and which pistons to use If the intake will work with my block and hitachi carb If the cam is a good idea And will I need any machine work for the heads/block to use all this stuff thank you guys Sorry If I seem clueless I’m only 18 and have a brat for a project
  19. Do you know we’re i can get those pistons and crankshaft
  20. Could you link your sources or the forum this is from so I can check it out
  21. Hey guys I’m building a brat with a ea81 (150k on it) and wanted some extra ponies in case of an emergency I’m going to polish the intake and open the exhaust a little are there any ways to get a significant boost without turboing and making it a fuel injection thanks in advance
  22. thanks guys not going to run nitrous
  23. Hi guys I have a ea81 and I want to run a 50 shot of nitrous don’t know a lot about nitrous yet but want to know if it would be safe before I invest a bunch of time the engine has 150k miles on it and I plan on driving it home afterwards thanks for the reply’s in advanced
  24. Any chance you could leave a sound clip
