SubaruLover20
Everything posted by SubaruLover20
  1. Gloyale first of all no need to be rude or offensive and second of all I was asking if there was a bigger engine I could swap because where I live there ain't any subarus so I was gonna see what I could but I guess I will have to just get another 2.2 thank you general disorder
  2. Well is there any engine from a Subaru that would be a little bigger that I can swap out
  3. I can't afford it guys I'd love to just get an engine but I'd have to go two states over to find one my issue is that I'm not used to a box engine I'm used to v8 and inline 6
  4. Hey guys been too long I need to replace the rod bearings in my 93 Legacy 2.2lh4 but I don't know how to do this without pulling the engine out
  5. The whole reason I want it deleted is because it's another thing for me to worry about and adjust I don't like the hill holder I want to feel my car roll back a little so I know that my clutch is working properly thank you mike104
  6. This is exactly what the problem is the only other issue is that I can't sell the neon rims where I live because no one wants to give me ten bucks for them I need spacers to fit in stud hole of the neon rim to close the gap so my rims are centered I just don't know where to get them
  7. Me again I have rims on my 93 Legacy and they are off a 2000 dodge neon the "fancy" alloy rims and there is a gap inbetween the lug nut studs and the rims I need spacers, "not wheel spacers" but I don't know where to get them or what size they need to be.
  8. Mike 104 would you be able to present a photo of it in the open position so I know what you mean also should I install a clutch return spring if so how
  9. Is it unsafe to delete the hill holder without adding a return spring or should it be ok without it
  10. If the torque on the bolt is set 8.7+-0.7 ft lbs would ten ft lbs be ok or to far
  11. Thank you so much this is wonderful if you don't mind me asking where did you get all this info it's amazing
  12. Well thank you for the advice but I don't like it nonetheless I'm used to my old school chevy clutch so the hill holder is wierd to me lol but I found someone who can take it out for me without affecting the car
  13. 987687 Thank you. you wouldn't happen to have anything on clutch adjustment would you?
  14. I'm about to pull the head off of my 93 Legacy 2.2h4 non turbo and I need to know the torque specs for the bolts any advice is much appreciated.
  15. Yes my dear end sags but I just can't take the hill holder anymore it's really annoying and agrivating.
  16. Subaru Fanatic! Thank you but the clutch adjustment is not appearing for me
  17. I have a 93 Subaru Legacy L non turbo sedan and I need to know how to adjust the clutch cable and also how do I safely disengage the hill holder it is causing a lot of problems and too much wear on the brakes.
