rzirker
Posts posted by rzirker
Well, I just found a good 95 to use, with egr, but I'd still like to know if someone out there could point me in the right direction for a list. Seems like it would be a very useful sticky.
Hi, tried to search but 2.2 and EGR wouldn't work.
I'm wondering what year/model/trans had 2.2 with EGR. Doesn't matter if I have swap the Y-pipe.
I know the 95 legacy 5 speed had one, but they are getting hard to find. Any others? Or other ways to do it?
Also wondering if a 2.2 will swap into a 99 OBW. I know the 99's were an odd year.
Thanks for the help!
and what other reasons are there for fourth gear to quit?
front speed sensor would be my guess, but i've never heard of it causing no 4th gear. did you run the rpms up until you hit the rev limiter, that should make it shift.
How high is that? Been to maybe 4200 with no shift.
1999 2.2 Legacy, automatic, 100K, the speedo is not working and the tranny will not drop into fourth/overdrive even when warm on the highway. Stays up at about 4000 rpm to do about 60/65 mph. No CEL.
Searched all over the boards and couldn't find any connection. Couldn't find anyone with just fourth gear out.
Hoping it's the VSS speed sensor. ??
Any ideas would be apreciated.
Pull your thermostat out to keep the pressure from building. Try to keep your rpm's below 3000 and you could last a long time.
Worked well for me. Good luck.
.... and they are?? All the ones I know are part of car-part.com.
Thanks
I'm looking for a black hood for a 2002 GT wagon, which is turning into a difficult task, but I'm also looking for a good supply of random parts from somewhere other than car-part.com (though they are a great resource).
Anyone recommend any other off-the-radar sources for Subie stuff?
Thanks.
OK, I did it. 3 nuts on the Forester. Hairdryer blowing hot into the inside for a couple of minutes, steady firm prying pressure out and the black goo lets go just fine. And there was plenty of goo on the salvage yard replacement to just warm it up and press it back in.
Thanks for all the help folks!
Hmmmm. Ok, sounds a little extreme, but I'll try some heat tomorrow. Thanks for the reply.
Have a 98 Forester with a broken tailight lens. Took a couple of 8mm (3) nuts off the inside, tried prying, doesn't seem to want to let loose. I don't want to break more stuff.
Anybody done this? Please advise.
Thanks!
Time to put in a plug for our buddy, Jason, at Mike Scarff Subaru in Auburn, WA. Nice guy, knowledgable and has always had better prices than other online places in my experience. West coast location makes little difference since everyone ships stuff everywhere anyway!
Call 866-528-5282 and ask for Jason in parts.
I second that. And I get it shipped to Ohio. Still the best deal and best service. Wouldn't shop anywhere else.
If it is the 2.5, then yes, that is the right part number.
Just if anyone knows: is the website now running by other dealership? they seems to have also prices below 'listed' but toll free number is different from older Jason's. I am just curious if I should go forward and order from them or look elsewhere ;-)
Forget the website. Call 866-528-5282 and ask for Jason in "parts".
write it down
Primary check:
Put your nose in the plastic overflow tank. Smell exhaust/oil/gas? Subtract $1500 from the price.
(and even if you don't smell anything but antifreeze, you know those head gaskets will blow soon.)
Put a 2000 5-speed in and it worked fine. So glad. Rear end is the same in all Foresters through '04.
Also want to mention an engine swap that a friend did, 95 2.2 into a 98 Forester, worked fine too. Noticable lack of pep though.
Thanks for the comments and suggestions.
The tranny should swap out. You will have to contend with the 8 bolt v. 4 bolt though. Make sure the final drive matches as well. If you can't verify get the rear diff as well.
Which tranny? Down to a 98 or up to 00-01? Rear diffs are all the same ratio.
Thanks.
99 Manual trans is shot. They are hard to find and pricey. Can I rig a 98 Forester 5-speed or an 00-01 5 speed tranny into it?? There are lots of them and they're cheap.
Maybe have to take 4 of the engine bolts out?
Anyone tried swapping one out? Swap swap.
Thanks for any ideas.
go to wal-mart, buy a can of recharge for $12 with a coupling on the end. DIY doesn't get much easier than this. If you have a problem with Wally-World, go to Auto-zone and pay twice as much.
Anyone know if this will work?
95 legacy 2.2 has dual port exhaust and EGR. (Got it originaly to swap into a 97 OBW)
I have a dual port Y-pipe (from the legacy) if the Impreza is single, but are the lengths/fit the same?
If you've done this operation or if you at least know if the 99 2.2 is single or dual port exhaust, it would help me out to hear about it.
Muchas gracias.
Absolutely the best?
Jason at Auburn Subaru
866-528-5282
That's the info I was looking for. Let me know what you find out about the wiring.
Thanks.
I searched around but couldn't find anything on this.
Problem: the 2.2 I bought has no egr on the manifold. has dual exhaust ports, but how do I remedy the egr issue when swapping into the 96? Any related wiring issues?
Also, the 2.2 is from a 5 speed and the 96 is an auto. That OK?
Thanks for the help.
Which year 2.2's have EGR in intake (for swap)?
Posted
I was afraid it was random like that. I appreciate you answering.
