cmarnold
Everything posted by cmarnold
  1. No push button start Yes auto headlights Yes DRLs No turbo Appreciate you and others responding to my plea for help before I hang my head in defeat and go to the stealership (no indie Subby expertise around here). -CMA
  2. Hello, everyone. I'm newly registered to this site and have an odd one to request some insights into: [*]One low beam bulb (9005) does not work. Swapped sides with the correct (and working), matching low beam bulb and the original side still did not work. Brand new bulb tried on both sides to verify as the same. [*]All fuses were intact and the lighting-related fuses were checked for continuity and swapped around. No change. [*]Swapped the high/low relays from one side to the other. No change. [*]No power to the side not working but that's sort of to be expected from the diagnosis. No visible corrosion or breaks in wires. [*]Front running, fog and turn signal lights all work. Here's where it gets stranger: [*]No high beams on either side. New bulbs (H11). All fuses/relays swapped with no change. [*]High beam indicator light on the dash works when the lights are flashed or set to "on" (forward and back positions on the switch handle). [*]Cycling through the lighting options/positions on the switch works (minus the dead low beam and both high beams). All of this occurred at once. My wife claims to have heard some sort of "pop" sound but didn't think much of it. I'm getting to wit's end as this just doesn't make sense. I'm going to retest everything with my multimeter up and down the wiring harness but that's the last thing I can think of short of not driving it at night. Thanks for any help you may be able to offer. -CMA
