WillRXsti
Everything posted by WillRXsti
  1. I don’t seem to be able to get an accurate reading on my dipstick. I have a 96 Outback with an EJ25. the motor is a replacement. Are there different oil pans?
  2. I did replace the thermostat but I don’t remember what it looked like if I don’t get the desired result by burping it I’ll pull the gooseneck off and take a look at it
  3. Got the job done thank you all for your help. Now the temp gauge is pegging out hot. I didn’t notice that happening before. I’m going to burn the Chiltons at my next bonfire.
  4. Thank you I am going to dive in right now and get back to you shortly
  5. Hello All I changed the timing belt and screwed it up. I replaced all the idlers, the water pump and the tensioner.rotated the engine by hand numerous times to double check for interference and there is none. I failed to line up the cam marks correctly I am ready to remove and reinstall the belt when I turn the crank so #1 is at TDC the key way is not at 6 o’clock more like 3:30-4:00. I am using a chilton manual and the guide that came with the continental belt kit. It cautions against moving the cam pulleys. I will need to move them just slightly. From the photo can you tell me if the crank is in the correct position
  6. Once owned 79 4 x 4 wagon the best combination of front wheel drive and four-wheel-drive I now own a 1996 outback Legacy wagon this looks like a very fun message board please feel free to give me specs a 4 inch lift kit
