Vert Umnus
  1. Most definitely had a ground connection issue. Bought heavy duty battery terminal clamps with set screws to tighten the cable to the connector.. and cleaned up and tightened the various grounding wires in the engine compartment. Strange but after that fans work fine now.
  2. Well done ! I noticed that the fans were erratically working, found a poor connection at the battery... gave a good cleaning and a good tite connection/ with new heavy duty terminal clamp.. and the fans came back on... coincidence maybe. Seemed to solve for a while Now back, no cooling fans no engine service light. Dont have a tester for engine codes plugged in green connector by accelerator peddle Drivers fans starts for a few seconds, then stops. passenger fan does not start both fans work if I jumper the relays. Humm thinking ECM or relays I’m found this on YouTube VERY helpful...,steps on your troubleshooting cooling fans https://youtu.be/YElByNoAz90
