Everything posted by Squidbilly503
- Alternator not charging
Naru2 so with the fuse in and the plug installed on the back of the alternator there is no voltage at the fuse. Remove the plug and there is power on both sides of the fuse. I thought that it was a contact problem in the the fuse. Removed fuse and cleaned contacts. Installed a brand new fuse. Still the same outcome
I’m new to this Subaru forum. But touching on this older post. I have an 84 1800 gl, and it’s not charging. Put new alternator in, new battery, all new battery cables and grounds, new fusible links. Test the fuse on the fuse block and I have battery voltage on power side of block with fuse in, test the other side of block and there is nothing. But when I remove the L plug I get voltage on the other side of the fuse. This is a real humdinger to me
Alternator issues!
