Lifted glwagon
Profiles
Posts posted by Lifted glwagon
I going to be doing an ejj 22 swap on my 88 gl wagon and I'll have absolutely everything including dash, gauge cluster, etc from the donor car, will I still have to make my own harness if I just swap everything over? I know it's gonna take alot of work, but is it possible??
Thats what I was thinking because I measured the wheelbase length wise on both cars and it matches haha thanks a bunch guys
So what youre saying is that I cant use the rear drive shaft from the transmission to the axle from the sedan 86 and put it in the wagon 88
So I have an 88 gl wagon and it needs a new driveshaft, I also have a 86gl sedan, will the driveshaft from the sedan work in the wagon? Because I really dont want to spend 400 bucks on a new one haha
So I have an 88 gl wagon with 33's on it and I want to be able to do highway speeda comfortably, does anyone know what gears I should buy?
I took off the pannel for the divers side and the motor smells smoked but I didnt take it out to see, tomorrow im gonna pull all the carpet and seats out to access everything easier and just start unplugging connectors until it stops blowing fuses n then I'll see if I can narrow it down after that
So I found a short in the rear driver side door and I put a new relay in amd even spliced a new connector and it was still dipping the battery and blowing a fuse....... Do I have another short?
That sounds right about where the sound is coming from, thank you, im pretty sure I smoked my regulator for the drivers window also, haha so im gonna unplug the regulator and see if I keep popping fuses like i have been.
Thanks everyone for the advice, yes I was using the window right before it happened, I'm going to check all my connections closer tomorrow and my fuses, I'm pretty sure I know where its coming from, ill keep u guys updated, thanks again.
So I was driving in my 88gl wagon. It has power windows and smoke started coming from under my drivers door pannel so I pulled over and took off the pannel and no more smoke. So I put it all back together and my windows wont work now. Also since then I hear a soft click from my passemger side and the battery gauge drops significantly and then a louder click right after and the battery gauge goes back up?? The clicking happens about every 10 seconds, Any ideas??
82 to ej22 swap
in Old Gen.: 80's GL/DL/XT/Loyales...
Posted
This is all super helpful, thank you, now not only do I have the ej22 but I have the factory 5 speed as well, is there anything special I need to know or will it bolt up??
