Cormfra
Profiles
Posts posted by Cormfra
10 hours ago, Step-a-toe said:
It might help again if you can identify the wiring your gifted friend shorted out. Where it is located, more importantly the colours, main and trace
Someone may recognise it.
It’s all the main radio wires I don’t remember off hand but I’ll look
3 minutes ago, rickyhils said:
Without ECU the car will simply not run at all. I know that much at this point. You need to check voltage going into the ECU. Undo the three 12mm bolts at ECU and unplug connectors. I think check for voltage with the key at ON position. Not sure which pins.
I will see if I can find out the pins
On 6/28/2020 at 5:13 AM, Step-a-toe said:
Give us some background?
Was running fine for you for years?
Or you picked it up as a project with a no start?
Something that may help us help you.
Starting to think every no start needs to be asked for compression test and go from there.
Is it a broken dizzy side timing belt causing this no start?
Pull dizzy cap off and confirm rotor turns with engine, you have rotor at all and intact carbon brush inside centre of cap?
Know how to test a coil?
Back ground
Got it to be a daily drive I drove it for about a month then my friend tired to put a radio in he didn’t discount the batter and shocked him self. After this it didn’t start no spark I checked fusible links, relays, fuses, new spark plug, new distributor cap does spin when cranking, new coil, new coil bracket made sure it’s wired right, spark plug wires are good
- 1
On 6/27/2020 at 9:57 PM, rickyhils said:
Then as General Disorder said- power supply issue. Even if no codes you should see several blinks in succession as a normal "alive and well" indication.
So something it’s something with the ecu
On 6/4/2020 at 1:34 PM, rickyhils said:
Grounding for ECU should include both the mounting bracket under the driver dash AND the heavy wire eyelet [in the harness] that bolts onto the thermostat housing. Check those. And, just curious, with ignition ON and engine OFF, how many blinks does the ECU show. Maybe six blinks that repeat?
Sorry I’ve been really busy lately. There are no blinks I also could not find the heavy eyelet on the wiring harness
I did make sure the brakes are good and tight and test for ground just in the out side of the ecu
To the ecu? So ether a ground or bad connection
That wasn’t it
if I got a new Ecu would that fix the ignition pause
Okay thank you
Okay thank you I’ll try tomorrow
if it’s not that any ideas on what it would be
I tested the corrent on each side of the links all reads about 12.8 to see if the current was making it threw and I also tested the amps and there all .30 of my thing is set right I’m pretty new on this stuff
Not sure if this feed is still active but is there any test I can do to test a fusible link and if so how do I do them
I have a no start no spark
How do I test them just the amperage
Thank you so much. So this would also case it not to start
I will double check but there is no blink
Alright
it’s the only thing I could rhink I shorted something out beside the radio and ever senses it hasn’t started and something’s haven’t been work
I have a 1990 Subaru loyale with a no start no spark I’ve replaced ignition distributor made sure it is properly wired the only thing is the ignition pulse if I’ve done the test right with a test light. there is no pulse. There is also other random stuff that doesn’t work on the car , lights, dash light etc. I wondering if it is infact the ecu that isn’t working and if not other things it would be
side note there is no check engine light or codes
Sorry I haven’t been on here for awhile
there is no pulse does this mean there something wrong with my ecu
there are no codes
I have the test light I’ll try that tomorrow
it should pluses when cranking
brand new coil
Okay so it should spark if there voltage on there side of the ignition coil correct and what would cause it to not spark even though there reading 12 on both sides.
there are other random stuff not working on the car I’m wondering could it be something with the ecu
Positive on both sides of the ignition coil
thnak you that’s how everything is set up and still nothing
Is the yellow wire supposed to Read 12 or anything
Yes it has two wires
so what are you saying I should do
So I guess I need to figure out what’s on the other side of the round connector
I need help finding out if I need a new Control Unit or ecu on a 90 loyale
in Old Gen.: 80's GL/DL/XT/Loyales...
Posted
Thank you
I’ll see what I find out
