86 xt
Everything posted by 86 xt
	Hi i Have a XT 1986 that starts but goes too 3k rmp then drops to 0, ran fine a week erlier, been started and moved a couple of times between that time with no start issue or idle issue, was on a drive a few days ago and the coolant temp got high then it started to jurk on the way and now it starts but goes too 3k then down to 0 things i have checked is spark is ok fuel is ok groundwires is ok maf seems ok have tryed another one same problem tryed disconnected the 02 sensor same problem tryed switching the cts sensor other, might be bad aswell the ECU gives 1 longer blink then 2 short trublecode 12. any ides what could be wrong or what else to try? kind regards from sweden
Front parking brake assambly '86 xt
86 xt replied to 86 xt's topic in Old Gen.: 80's GL/DL/XT/Loyales...
Okej, thank you for The info, Will post when i try it after assebly -
	Hi, I need help to know how to put this together, have tried everything possible, but can not find any sensible picture what it should look like or what direction the lever should sit. Has anyone here done this before who can explain or have pictures from the assembly?
