Everything posted by SVXdc
99 Legacy Outback Aftermarket Headunit Install Power Antenna Problem
SVXdc replied to kamusta1's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe Pioneer DEH-P6700MP only has the Blue/White "Amp Remote" wire. It does not have the Blue "Power Antenna" wire. So it's working correctly. If you don't want the antenna up while you're listening to CDs, the only solution would be to install a switch on that wire.
98/99 cd/radio combo fit a 94 legacy?
SVXdc replied to hugh77's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThe 98/99 will probably fit. Every Subaru radio I've seen has been double-DIN sized. I'd be very interested to know whether the wiring harness in your '94 is the two-plug style or the newer, single plug style (with 14-pins). The two-plug style was used by most Subarus up to '92. In '93 they switched nearly all models to the single 14-pin plug. But some '93-'94 Legacies continued using the old two-plug harness. I've been told that all North American '93-'94 Legacies carried over the two-plug harness. If you end up needing to create an adaptor using 'forward' and reverse harnesses, you don't want to use Scosche's reverse harness -- theirs are missing one of the two illumination pins; without that your radio won't light up. See this post for harnesses that do have all 14 pins.
Stereo and Speaker Install - 93 Impreza
SVXdc replied to subiefan's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXThis post (or the links within) will answer many of your questions: Stock head unit information -- pin-outs, aux inputs, and more According to Subaru's wiring diagram for 1993 Imprezas, these are the positive speaker wires (at the speakers): Front: (both Right and Left)- Red/Green Rear: Right- Blue/Green, Left- White/Red
Stereo head install 2002 Impreza RS
SVXdc replied to luca_brasi's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXSee this thread: Stock head unit information -- pin-outs, aux inputs, and more
Radio connector pin-out tables for most recent model Subarus
Radio Wiring Connector Pin-outs Includes factory wire colors and the matching after-market wire colors: For the Impreza/WRX and Outback Sport (all years since 1993) For the Forester (all years since 1993) For the Legacy, Outback (non Sport), and Baja (all years since 1993) SVX Audio Installation Guide (includes radio connector pin-out, plus information and tips that will apply to installing radios in other Subarus). Yahoo Geocities will die on 10/26. Would you please edit my post to change the root URLs in my post from "http://www.geocities.com/svxdc/" to "http://ae64.com/" The URLs on the new site use the same filename/suffix as the old site. Thanks!
Head Unit Replacement - 99 Forester
SVXdc replied to MEX's topic in 1990 to Present Legacy, Impreza, Outback, Forester, Baja, WRX&WrxSTI, SVXPin-out of the Radio Wiring Connector in the Forester (all years since 1993) A wiring adaptor really does make your installation much easier. Definitely worth taking extra effort to find and order one.
