newmexguy
2
Posts posted by newmexguy
A southern NM example would not have had any rust on the lower door seams, or rockers. But theyre all gone now. The three that were in the Ruidoso area, a while back, as a PACKAGE deal, probably were similar to this one. In terms of body condition. But was too far from the buyers, to risk it.
Guessing that one was rolled. Moss in front seat Likely weather there, is more like northern Japan, or the pacific northwest. No moss grows here in the desert! Doubt you'd find any in the outback either.
These cars are not "nose heavy". Is power steering really needed?
Nuts. NO way to run a side gig. I've never made enough selling parts to make it a primary gig, but I sure wouldn't stiff or ignore a customer like that. Simply would keep the communication lines open, and let them know it will take some time, due to primary Job committments.
Many are living for that next "thirty Pack" as well. Although Bud Light might be a little less popular right now. Darn if someone was offering a G for a pile, sitting near the Crusher, I would have chiseled off, and kept the VIN plates if there was no title.
I still have those manual racks, figured they were worth more, than power ones when these cars were in the yards a decade or more ago.
Have a pair of hubs, with turned rotors, along with cone washers and castle nuts. If you are still in need. This is EA-82 stuff.
Dave S southern New Mexico (clean parts).
- 1
I have a Replacement Copper / Brass radiator. Near new, but some cosmetic defects. $40. PM if interested.
Yep, I have an '89 parts wagon, but it is not the same as the "carry over" brat which continued to use pre '85 passenger car stuff.
Looked at my three shaft assemblies - that have that carrier bushing.
1. one front unit is "shorter" with good bushing and bad front U joint (guessing five speed?)
2. next front unit is "longer" with good bushing and good front U joint (Auto?)
3. Third Unit is complete assembly, long front shaft, has good U joints (has Subaru Sticker, may be replacement assembly) I did buy it from a Yard, perhaps a Decade ago, as a complete driveshaft assembly
Had these loose, for so long, forgot which is Auto and which is Five Speed
Since you already sprung for the $$ rebuild kit for the Original, I'd find a Carb Guy to fix what you have. Keeping it all original. I do know one here in Las Cruces, he was employed by the now defunct Pony Carbs for a spell. Frankly I'd look for one that has a Japanese focus, or sideline, there has to be more than one out there.
The southeast is not a hotbed for these cars, and if you desire to part it out, you'll sell one critical part, and since then the vehicle is disabled, there's no way to sell the rest. For above Scrap value - say $150 when brought across the Scale. Shipping and Logistics kill me in southern NM, as pretty much everything I sell in my main focus of 64-81 GM classic has to be shipped out of here. Would suspect you'll have the same problems, with Subaru parts, in the Southeast. The areas of interest for the older Subaru tend to be the Pacific NW, the Northeast, and Colorado/Wyoming. In a very general sense. There are always exceptions.
I have a parts EA-82 on a stand right now. Clean desert metal. If you need any hard parts let me know. Also have new timing belts, gaskets, hoses, thermostat, etc. All new. Package deal if you buy it all.
Have a older replacement copper/brass job, near new, a few cosmetic blems. Available. Would imagine anything available now is aluminum with plastic tanks.
Ok - that seems to indicate that the "carryover" Loyales used the earlier tank.
www.subaruparts.com - shows some pre '95 parts still available.
Spectra Premium? Rock Auto?
I have a cleaned Wagon tank, it is in my Classifieds Ads
Dave S southern NM
On 5/5/2022 at 12:00 PM, 1980ea71Brat said:
I have done some research on this and it seems the part number 85111GA153 has been discontinued across the board for basically all 1994 leones and older with the analog gauges.
My question (not to steal this thread) is can we adapt a universal fuel sending unit to our tanks? Has anyone used a different make and model part as a replacement?
I have a flushed / cleaned tank from an '89 wagon. sender/float is clean. Research seems to be that it fits '87 to '89 only. Any reason why this same setup wasn't used in the "carry-over" '90 - '94 Loyale Wagon models?
Pm sent. Dave S.
Yours gone, or trashed? I've got an '89 wagon, I'd be willing to sell Drivers seat, but doubt it matches your fabrics.
Dave S
Not trying to Hi-Jack, but have an '89 Wagon 650 miles south, in Las Cruces NM area. 5 speed 4 x 4. Weathered paint and sun damaged interior plastics, vinyls, etc. Very Clean underneath. Maybe both of these Cars can be put together? Will Sell it for $400 without the Engine and Five Speed or $600 with. With All remaining '85 - '94 Compatible parts - $1000. There is a Title.
- 1
If you had had this vehicle 24 plus months ago, the local yard had several donors that could have been cut up. But they crushed out in Oct '20. Closed. Done. The pick a parts down in El Paso do not allow saws, for most part, and to most individuals. Liability issues. And these cars have dried up, even down here.
"73 Green coupe "Leone"? currently on BaT. Appears to be a near full restoration. Missing some interior plastics. Runs and Drives.
Still under $5000 I have no idea of the value of these. Roseburg OR location stated.
New GL Wagon Owner!
in Meet n' Greet. Your USMB Welcome Center
Posted
I've heard the VT title thing or "loophole" has closed. Not an expert, however. Others have said Alabama has a "looser" process. If you had been closer, would have given you a killer deal on the '89 DL wagon carcass I finally liquidated. It had a title. Still have near complete new gasket set, plus more new for the EA 82 engines, will make a package deal if interested. Dave S.
