Everything posted by vesparex
Anyone know of other make cars whose wiper arms will work on our splines? My pin arms are tired and the wiper blades have had the rubber refills replaced so many times that the metal is nearly cracking. At minimum maybe where to find the pin blades as in picture to get new, soft ruber again. LOL
Poor quality because I had to compress so much vcompress_4.MOV
So it was the radius rod. It was "Z" shaped and I straightened it. Shes back to her old self. Door tirm reattached but that front fender, well, its flatened pretty well. That lower control arm only has a slight bend but as stated above, the rubber bush takes that up. Thanks everyone. She lives for another day or 3,650 more! As a follow up as I havnt posted here in a while; She is my daily here in Denver. City car by weekday and Goat on weekends. Endless fun doing donuts when we get snow and I find and empty parking lot.
Can anyone tell me deffinetivley if the lower control arm is the same for 2wd and 4wd? My baby was involved in a hit and run last night in front of our house here in Denver and they pushed the left front wheel back, bending the left lower control arm. I have a full front clip from the same year model 2wd.
Hello all! I'm curious, has anyone seen or heard of anybody else fabricate a way to install ATV Portals to an old Subie? https://www.superatv.com/utv-portal-gear-lift does them for all types of side by sides. 3 gear so they do not run backwards, and housings machined from aluminum to reduce their weight. Duane
81 GL Hatch Front Camber Adjustment
vesparex replied to vesparex's topic in Old Gen.: 80's GL/DL/XT/Loyales...
I messaged you with a question. And thanks again! -
I have been to their website (and follow on IG) but never saw stuff for the early Soobies. I'll email Patrick and see what he has. Duane -
Thanks GD. Know of any suppliers for my old EA81? Duane -
So I bought my car with a previously installed 4" lift. The front camber is awful. What have people done to try and reconcile this? Thanks, Duane
Can anyone tell me the back spacing for these 8 slotted steel wheels? Thanks, Duane
Maybe instead of worrying about gears, I concentrate on an EJ22 swap. Make up for lost torque in the tire size with a bigger engine! D
GD, I saw in a search you mention a Toyota trans swap. Is there info on this out there anywhere? Duane
Thanks guys. I realize what I have. My wife and I own a New Jeep Cherokee and a 1968 Bronco. So I'm not trying to replace something. I just love these little buggers and am curious what there are for options. Maybe I'll just concentrate on a little more power (ie engine swap or fuel injection bolt on) and building a more compliant suspension. Sunday was our first time out on trails with the little GL. Performance was actually surprising. But holy hell does she ride rough. I was just curious if we had any option to gain a little more torque that was lost in the 27" tire upgrade. Duane .
Good afternoon, Took my 81 GL out on trails over the weekend here in Colorado. Did ok but with 15" wheels and 27" tires, she could really benefit from lower gears. I've read about Foresters having a 4.44:1 ratio gear set. Are these swappable into the GL's trans and rear diff? Duane
So going to replace the front axles on my '81 GL hatchback 4wd. Any tips or tricks? The Haynes says I need special tools. I am sure this is doable without Subaru specific tools at this point 39 years later! D
Good morning all, Could I use rear axles for the 1985 GL in my 1981? Duane
This is good news! I appreciate the input. I found 2 decent used here in Denver. Will be very interested in the links if you guys think of them. Duane
Good morning all, Just bought a 1981 GL 4wd and I am having issues finding replacement rear CV axles. Can anyone point to a vendor or part# I can search? Thanks, Duane
