pa9213
Posts posted by pa9213
Thanks for asking. I have replaced the Voltage Regulator and I have tested the Fuel Pump and it runs well being jumped from the car battery. The fuse box is located under the dash and I have checked all of the fuses and they are good. I will be rechecking them because my son say that the engine fuse may have something to do with the fuel pump. I have also found that the fuel pump wiring goes to the EMC box. I have not had time to check the wiring to see if it could lead me to what is keeping the fuel pump from running when starting the car. I have started the engine by putting gas in the carburetor. The engine runs well accept the fuel pump. Paul
The fuel filter is located at the back drivers side wheel. Under the body. The fuel pump is located under the hood on drivers side just in front of the steering wheel. You can check the fuel pump by unplugging the pump and connect a wire to the positive battery to the multicolored wire. The ground is black connect it to any ground and you should feel the pump and hear the pump run. If the pump runs their is a fuse somewhere. I am looking for it on mine. When I find it I will let you know where it is. Good luck. Paul
Can you tell me where on the 1981 Subaru DL 1.6 engine the Fuse is for the Fuel pump?
The Wiring Diagram the Wires are colored different on mine.
I have checked the fuel pump and it runs.
Any help would be appreciated.
I have a 1981 Subaru DL 1.6 engine. I cannot get fuel to the carburetor. I have not started the car in about 2 years. I have a new fuel filter located under the car at the back and no fuel gets to their. My fuel pump in located under the hood. I have started the car with starting fluid and it runs fine for about 3 seconds. Could someone suggest what I can check to locate what is wrong?
Thanks Paul
Your fuel filter is located in front of the Drivers side rear tire under the car. Your fuel pump in under the hood under the wiper motor. Good luck.
Paul
I have a 1981 DL 1.6 motor. The fuel filter on this car is under the car behind the rear driver side. The fuel pump is under the hood. It is on the right side as you stand in front of the car next to the fire wall at the windshield. You may want to check the carburetor. I had this fuel problem. I found that two black small hoses that go to the carburetor on the right back had come loose from the carburetor body. If this has happened you cannot get fuel. You have at least 8 PSI which is lost if these are not sealed in the body of the carburetor. I will have to glue or something else to make my work. I am checking to see what is best. Good Luck
Paul
- 1
I have a 1981 DL. I am getting it back on the road. I have replaced the boots and the axles. Most people will tell you to replace the axles. The cost is not that much different. My experience is the only thing that goes is the boot and the bearing on the axle at the wheel. Good luck with the replacement.
I use Rock Auto a lot. I like them.
Paul
E-Mails are confusing. I will try to explain mine.
pa9213si(eye)l(LUG)@gmail.com
We will figure this out. Thanks for not giving up.
By the way I could not find any of the E-Mails you sent.
Paul
Thanks so much for getting back to me. I don't care for FB but look their mostly for kids and grandkids. I will join to see if the info you have will help. I will let you know.
Thanks again. Paul
I for some reason cannot get facebook to let me join the group.
Would it be possible for you to E-Mail some information? pa9213sil@gmail.com
Thanks again
I need to locate a detailed drawing of the 1981 DL 1.6 Carburetor to show how to put the parts on the Accelerator Shaft. I do not know the order that they go in.
I bought this vehicle new in 1981. It has taken me through snow, rain and allowed me to stay alive when big trucks wanted to move me over. (I hope just didn't see me)
The carburetor does not have and numbers on it that I can find.
Thanks if you can help me at all.
pa9213
Fuel pump wiring information
Posted
Does the electric fuel pump run? Mine was not getting any power to it. I have found I have a wiring harness wiring problem. Have not had time to fix but have located.
Paul
