Everything posted by PhantomSubaru
Thank you for your input. I was far away on vacation now back in the neighborhood. It sounds like either one of those plugs being loose would cause non-starting issues. They seemed to be tight but maybe not quite fully seated in their proper placement. Or else I have a poor ground somewhere else or loose connection which would explain the intermittent starting. I hate electrical issues but at least I am learning things along the way.
Thank you for your input. I was far away on vacation now back in the neighborhood. I will double check on the codes when I return to work on the Subaru. I know for sure the pump primes when turning the key and there is plenty of fuel pressure. I will double check my brake booster hose and other vacuum hoses.
I noticed something yesterday that may or may not be related to the starting issue. After pulling the key and opening the door, the open-door icon lights up on the instrument cluster as if the ignition were still turned on. The ignition itself is kinda funky to get the key to the right place where it clicks when removing the key but I always make sure it does. I figure if the ignition were faulty it would not crank the engine though so maybe this is a separate issue.
Great advice on how to probe the harness without piercing the insulation. I will have to give that a try. So here is what I discovered today. Upon arriving I connected the positive battery cable and cranked the engine just in case it might have fixed itself. Nope. Next thing I did was fiddle with three large connectors on the back side of the engine, one of which goes to the injector harness. I did not unplug them but simply wiggled them a bit to make sure they were fully seated which they seemed to be. I tried the key again and it started. Go figure. I would like to think messing with that connector was what made it work but the previous time I had the non-starting issue I do not remember doing anything with that connector so I am somewhat skeptical. One thing I followed up with was making sure the grounding cable from the battery to body had a good connection which it seemed to be fine but I scratched it up just to make sure. I was looking for a ground wire somewhere between the engine and body but did not see one. Should there be one? I am pretty careful about marking everything when swapping engines but maybe that is something I overlooked.
Excellent. I will be heading out shortly do do some work and check out the Subaru. It sounds like I should leave the harness plugged into the injectors while testing and pierce the wire insulation with testing probe rather than unplugging the harness and checking directly on the pins? I would rather not pierce the insulation unless I have to but maybe they need to remain plugged in for this test. Will be checking the large connector and grounds to body too.
Thank you for the detailed information. Everything was fine for a few weeks of periodic starting to move the car around as needed then one day last week I went to bleed the brakes and the car would not start. Same issue as before. I pulled an injector plug and tested with a light. The light was on with the positive yellow wire. With the other wire the light was on but dim and it did not fluctuate when cranking engine. I will check the big connector between the intake and body. Where would I locate the two sets of contacts that are actuated by the main relay? Unfortunately my car is stored in a barn with no heat about 20 minutes away from home so working on it has been a challenge but I plan to go there tomorrow for some other work and check things out with the car. If anyone has feedback it would be greatly appreciated. I am good with mechanics but electronics are a weakness.
UPDATE: I pulled one of the injector plugs and hooked up my voltage meter. I got 12V+ then put the meter's prong into the other receptor and turned the key. The car fired up! I put the plug back on and cycled through a few starts just to make sure it was not a fluke. I am perplexed as to why it had not ran numerous times before but now it works so I am stoked. I have a P0270 code (cylinder 4 injector control circuit low) that was not there when I was previously attempting to start it. I hope I did not damage the plug while inserting the meter prong. Maybe it threw that code since I had the plug removed and has not yet reset. I should have erased the code and see if it comes back. That will be my next step when I head back out to the barn.
No backfiring and the IACV hose is connected. It crossed my mind the timing may have slipped somehow. I had rotated the gears while I had it out of the car but that does not quite have the same effect as a running engine. I am not sure how these systems operate but I wonder if the timing could be out even though it runs smoothly with starter fluid. As of now I am leaning towards a fuel delivery issue. I could be completely wrong though.
As the headline states, my 1998 Subaru Impreza OBS with EJ22 will not start. I am looking for troubleshooting advice from more seasoned mechanics on what the issue may be. Some background information... This car was my daily driver for a while and developed a rusted out rear subframe so I decided to do a major overhaul of the entire car. Part of that overhaul included swapping an engine with much lower miles. The donor was an identical 1998 Impreza OBS which was my previous daily driver so I know the engine was functional and was stored indoors for a few years while inactive. I carefully followed instructions on replacing the timing belt and coolant pump before placing it in the car. After everything was hooked up I turned the key and it cranked a few times before sputtering to life and ran gloriously smooth for about two seconds before cutting out and will not start thereafter. HMMMMM. I checked a few things. Upon removing the fuel supply line to engine it is evident I have plenty of pressure. I removed one of the plugs and cranked the engine which reveals it is getting spark. There is no blockage in the air supply that I can find. One bit of helpful information is the car will run as long as I spray starter fluid into the air intake. Does anyone have any ideas here?
