Zeky
Posts posted by Zeky
Hi guys,need u again.Where is the MPFI unit located i did seach forum but no luck.The diagram shows that the wires from relays goes to the MPFI...
Thanks in advance
Please please, have no idea what DUAL RANGE mean.....
Where did you find refrigerant without oil already added? Most if not all of them have the oil in them. Look at the can to be sure. . .
Oh , i forgot about this one.Well,may be u right i will check the can if the oil is already in there...
OK,now thanks.
2 Gnuman.Yes i did checked relays ,they are fine.
2 Legacy777 thx for the pic will be the hell to get to it.And no unplugin the sensor doesn't turn any of fans on.
I'll post the progress...
Oh yeah,Thanks guys u are right and the picture clear it all up.But i knew where the sensor is but didnt knew there are two.....
So if i unplug the 2wired one no fans start up.Just engine change RPM fluctuating for a while but then stabilize.If connected back do the same.This means that sensor is working i guess.So i am going to study wires diagram and find the right damm wire.By the way where is ECU located.
PS.A/C turns both fans on?My do.
Most auto supply places sell spark plug boot pullers. They look like pliers with the ends specially made for gripping the spark plug wire. You could try those too.
Yeah i advice you use them cose other wise u will broke wires and need new one
Of course if you just don't wanna change them
You can find wiring diagrams here
http://www.main.experiencetherave.com:8080/subaru_manual_scans/1992_FSM_(Engine_%26_Electrical)/
Hi ,didn't have time to post here sooner.I just realized mycar is 91 ..my bad
So those diagrams will not work for me or will they?....
I am getting crazy realy ,i have been jumping around the car with multimeter all weekend and no luck.... :-\
I just wanted to add that ATF change is not ment to be done when the tranny malfunctions but rather every 30000 miles as a part of maitenance. It sound like the AT is dying.
Yeah thats righ if its dying you'll just speed up process.
Sometimes tranny died after fluid change even there was no problems before.
Simlpy new fluid clean up the old gunk which hold tranny together.
So you decide.....
Good Luck
If you put 12v on pin 1, and pin 2 to ground
But i just put ground to it and it work, so maybe some bad grounding i guess...
thx for link
Well what u wannt to do is called "transmission power flush" and in the shop is about 90 buck's.The way u wanna do it by your selfits the good way and synthetick is definetely best choice.But Do it like this:
Find two(2) budgets big enough to hold all tranny fluid ,then fill one up with new fluid(find yourself how much your tranny need).
Then unhook both hoses from radiator and place the one which is sucking the fluid from radiator to budget with new fluid.
And the other one to the second empty budget then start engine and wait until clear red fluid start comming out ....
Connect all back ,clean the mess and u are done..
Later i will post a link to better directions from other forum ..(now is not accessible)
I would probably put one of the small cans of oil in, 2-1/2" oz
Yeah ,thats what i am thinking about.And by the way i am now living in US :cool:
And just share your pain and tell us what u did with your A/C
:banana: :banana: :banana: love this smile ...banile?
Ooops ,didn't uderstand...
add refrigerant until the pressures look good, and temps blowing out of the vents is good.And what about the oil?I did put in just refrigerant w/o oil and pressure looks good ,so what now?
Hi guys, my 92 Legacy main fan wont start so car is overheating.I checked
the fan end is OK.I try bypass the main fan relay and it works.
If i connect pins 3 and 4 (the pic)fan starts rights up - thats normal. But if i bypass minus right from battery to pin 1 (or 2 not shure right now) the fan starts too.... so is that normal?
What is switching relay to ON ?The coolant temperature sensor?But the temp gauge in dash works fine....
Any diagrams of it?Eny experience?
Thanks in advance....
1. Try jumpstart and u can try give a little kick with a hammer to your starter
2.If starter click loud try remove>open>clean>put together>install
I did the same 2 years ago and saved 70 bucks cose i have been told by mechanic to change starter....
They should change water pump ,timing belt tensioner end at least check all pulleys if neded change them also.Some people sey crankschaft seal to....l
How much of oil put in? They sell separate small and big can's of it... don't remember sizes
Buy a can that has oil & refrigerant in it. Oil should be esther oil. -
OK , so filled up and here we go its running strong
Just need to know if i should put some oil in
This is what i have ,so it has been converted but still doesnt work :-\ Later today or tommorow i will try to fill it to top and let you know...
THX
Consider fan is running ,but i think it may be already converted...
BUT HOW TO KNOW
http://www.ultimatesubaru.org/forum/showthread.php?t=33889
I appreciate your help
Can you get R12? If so I would top it off. If not you may consider converting the system. Is the condenser fan running? I can look up the symptoms in my book when I get a chance. -
Well, i think in/out play may be ok cose the stubs are removable.If its free side to side then may be a problem with differential bearings.But i am not sure about this.May be someone else will tell u ......
which is ok and which is bad?I read that thread and saw no mention of play or evaulating the condition of stubs.
My new CV is in now so I hope I had the "ok" play
Hi i got the sam eproblem "how to know if it been converted"
And i dont understand clearly what u mind by this:
R-12 fitting are screw on fitting and if it been converted to 134a there are quick disconnect style fitting on it (Usually)You may want to look around for any retro fit stickers
SEA#3
EDIT:
Well, may be i figured out i got this recharge kit(pic) for my other car and it wouldn't probably fit to R-12 right?And it fit to thicker hose(blue cap) the thiner one got a little bit bigger valve with black cap.
1.clutch is engaging when the A/C switch is pressed
2.System is R12
3.Evaporator fan is running
4.Pressure on the thinner hose is little bit under "FILLED" mark.I got only Gauge A/C filling set and it shows only LOW-FILLED-OVER FILLED
Thanks for your help
So the clutch is engaging on it's own? What is the low-side pressure with the system running? If you have dual gauges the high-side pressure would be helpful as well. I have found that the R134a systems start to perform poorly with only a relatively small percentage of the refrigerant missing. Is the A/C fan running? A poorly cooled condenser will cause poor performance as well. I assume the evaporator fan is running?I'm no expert but I do have a decent book and I will help if I can.
Hi, some free play is ok .Depends if its in/out or side to side.Take a look at http://www.ultimatesubaru.org/forum/showthread.php?t=33362
I'm going to be replaceing my front shafts tomorrow. While checking I noticed some play in the transmission axle stubs.How much is acceptable?
Whats the fix?
Thanks
Chris
93 legacy sport
ps this is 32mm axle nut right?
Hi, can anyone tell me how to find out if the A/C compresor is OK.Well all relays seems workin and clutch on compressor also.A/C system is not exactly full but not empty at all.All A/C hoses are hot.And two weeks ago everthing was fine....
So? Any ideas?
Main Fan not kick on
Posted
OK,now Legacy777 posted me this http://www.main.experiencetherave.com:8080/subaru/images/ecuhide.jpg and there is not a MPFI.So i dont know.
And if anybody know where is this DIODE located(red circle) ,it will be great.
